Go to Post I can attest that mentoring is probably the most important aspect of this program. - Tom Bottiglieri [more]
Unread 12-01-2008, 20:48
arpitshah arpitshah is offline
FRC #1514
arpitshah is an unknown quantity at this point
How to conect solenoids to the circuit board. and how to program it...???
we are having problem connecting the solenoid to the electronics...we can not figure it out that where to collect the solenoid wires on the circuit board. like we don't even know where to attach those 2 red and black wires and also that waht are they gonna do..we are thinking that those black and red wires are the one who will provide the power to the solenoid but than the quesrtion is that where we gonna attach the pwm like cables that will bring the command to the solenoid.... moreover we don't even know how and what to program to use the solenoids. the single swith solenoid is the one we want to use. So if u guys can help us out that would be really great..basicall we are trying the pneumatics for the first time so we don't know anything about the pneumatics.....thanks a lot...
Unread 12-01-2008, 20:55
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: How to conect solenoids to the circuit board. and how to program it...???
Solenoids draw quite a bit of current, so you can't connect them directly to the RC, they need to go through a relay. How you wire it depends on the valve you are using. Generally speaking, the relay will put voltage on the solenoid coil, which will in turn cause current to flow, creating the magnetic field that opens the valve.
So, you need to wire the solenoid to a relay output, then wire the RC to the relay using a 3-pin cable connected to the RC relay header.
-JEE
Unread 12-01-2008, 21:34
The relays which Jeff discusses are known also by the name IFI Spike. You received several in your Kit Of Parts.
Unread 12-01-2008, 21:37
Generator of Entropy
FRC #2973 (The Mad Rockers)
Check out the documentation for the Spike Relay on the IFI website, found here. It shows how to wire up single and double solenoids and what the different pwm signals from the controller to the Spike do for solenoid control.
Unread 12-01-2008, 21:54
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
To connect the solinoids you will need a spike. The black which is ground (negative) connects to the circuit breaker panel where it says negative and the red connects to the same panel but to a 20 amp breaker not fuse. The m+ and m- on the spike is where you connect the solinoid. I believe that you take a black wire from one side of the solinoid and a red wire from the other side and put a connector to it, do the same for the other two. Also the programming for it is the default code which i believe uses relay outputs 2&3. Not sure on that one but this stuff should help you.
Unread 12-01-2008, 22:00
That's the way I've always done it, but that's not what the manual says. There is an old thread debating the merits and risks of this method; I've never had a problem doing it that way, and the standard EasyC code library works fine with it either way.
Unread 13-01-2008, 15:06
Yea me too, never had problems with it and we've been doing it for over 6 years so it think it's fine, but we would do it the other way if the manual was more clear as to how to wire it.
How to program ir sensor board?? RRA4LIFE2 Programming 1 11-01-2008 21:47
how to assemble the solenoids MNov Pneumatics 2 09-01-2008 00:02
How fast does the Solenoids turn on and off? Generalx5 Robotics Education and Curriculum 2 26-01-2007 01:09
Anyone know how fast the Solenoids on the MINI RC can turn on and off? Generalx5 Control System 1 06-01-2007 07:39
Does anyone have an idea on how to make a joystick program for an operating board? necroprime Programming 8 09-11-2002 19:04
