Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
Unread 12-01-2008, 18:58
ubermeister's Avatar
ubermeister ubermeister is offline
AKA: Eric VA
ubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the rough
Competition port power
I'm looking to make my own disable switch with some logic chips and LEDs. Is there any way to draw +5 from the competition port? I know it's possible to power the OI with that port, but when it is powered by AC or tether, can it provide power?
Unread 12-01-2008, 23:26
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: Competition port power
http://www.ifirobotics.com/docs/comp...guide-reva.pdf
Unread 12-01-2008, 23:56
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
If all else fails, why not stuff some batteries in it? You aren't going to be using it during comp anyways.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 13-01-2008, 14:37
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
http://www.andymark.biz/am-0016.html
Unread 13-01-2008, 16:27
AKA: Eric VA
Yes, I've seen all of those websites, and none of them have any info about sourcing power, besides "don't do it."
Just for anyone else interested, today I took a voltmeter to the port, and found that pin 1 is at 12 volts. If you want 5, you can use a regulator.
Unread 13-01-2008, 20:27
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Keep in mind what the PDF for the disable connection says right in the center with big words. Connection to any other ping will void warranty.
If you want to power LEDs showing what the settings are at just use 2 AA batteries and a double pole double throw switch.
-Mike
Unread 14-01-2008, 23:32
mneary mneary is offline
FRC #1759
mneary is an unknown quantity at this point
Send a message via AIM to mneary
You'll probably find (as I did) that pin 1 is connected directly to the coaxial power pin, with no current limiting or fuse of any kind. The risk should be obvious.
Unread 16-01-2008, 17:08
AKA: Eric VA
Thanks for the help- my switch is built, just waiting for testing.
Unread 07-03-2008, 00:54
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
pin 3 puts out +5 volts
Power output on I/O port Leet_T3chn0 Electrical 12 03-12-2005 03:13
URGENT - No power from backup battery/PWM port voltage Sidney San Martín Technical Discussion 19 18-11-2005 12:16
Power from competion port rocko General Forum 1 06-02-2004 15:42
PWM port power rust710 Electrical 10 21-02-2003 13:56
Competition Port Dush General Forum 2 12-02-2003 23:00
