Go to Post Our team has one goal: be ourselves. - PayneTrain [more]
Unread 13-01-2008, 03:29
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: doing double integration to getdistance traveled
Originally Posted by eccmaster View Post
Has anybody been able to do double integration with readings from the accelerometer in the kop? How do you do double integration in easy c?
The key to the integration is precise, interrupt-driven timing.
When you take the acceleometer output, you can use the formula vf = vf + (a * t) every time through the program loop. If you use precise timing, you know the set time interval, you know the acceleration, and you know the initial velocity (this was vf the previous time through the loop), so you can solve for the new final velocity.
From here, we plug this into the distance formula of df = df + (vf * t). This formula finds out how far the robot would have traveled at velocity vf for time t, and then adds that onto the previous distance.
With a dual-axis accelerometer, you will need two separate sets of these equations, one for both the x and y dimensions.
Art Dutra IV
世上无难事,只怕有心人.
Integration of Gmail and Gtalk IraJason Chit-Chat 8 20-02-2006 10:26
Accelerometer integration Leav Programming 4 27-01-2006 11:56
CMU Integration Overview???? Mumford 406 Programming 1 09-02-2005 18:17
Autonomous Camera Integration GregC Programming 2 06-02-2005 14:34
Autonomous Camera Integration GregC Programming 1 05-02-2005 18:56
