Go to Post Amazing how great minds think alike! - Jack Jones [more]
Unread 13-01-2008, 09:29
Brian Connors Brian Connors is offline
FRC #1358 (The Generals)
Brian Connors is an unknown quantity at this point
Sensor Issues
My team is looking to build a tricycle with the rear 2 as drive wheels and the front as a steering wheel (no forward power, only turn). The other programmer and I cannot figure out what sensor to use to determine the angle the front wheel is at to make it return to center when the joystick centers. If this makes any sense please help. If it doesn't, please let me know and I'll try to reword it. Thanks in advance.
Unread 13-01-2008, 09:37
avatarrobodude avatarrobodude is offline
crazy programmer
AKA: Tye Radabaugh
FRC #2068 (Metal Jackets)
avatarrobodude is an unknown quantity at this point
Send a message via AIM to avatarrobodude Send a message via Yahoo to avatarrobodude
Re: Sensor Issues
Depending on the way that your steering is set up, you may be able to attatch a potentiometer to the steering axel, I guess it would be. Then it would be a simple matter of plugging into an analog port and getting the feeback.
Other than that I don't know of any other sensors you might be able to use like that.
My daily diet consists of: brackets for breakfast, pneumatics for lunch, software for dinner, and plastic tubes for dessert.
Unread 13-01-2008, 09:39
Re: Sensor Issues
Actually that makes perfect sense. we had not thought of that. Thanks
Unread 13-01-2008, 09:40
Gdeaver Gdeaver is online now
FRC #1640
Re: Sensor Issues
Warning! Our team made a trike before. We used a potentiometer for wheel position and 2 limit switches for calibration and safety. It worked but, the 3 points of contact make for a less stable robot than 4 points of contact. Also, that year each wheel was driven by worm gears. You need to do a little math to set the wheel speed for each wheel in tight turns. I would think twice about trikes.
Unread 13-01-2008, 09:45
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Re: Sensor Issues
If you can hook the potentiometer up to the shaft of the steering that would be your best bet. There are different type of potentiometer including Limitless and just single rotation. Both of these can be hooked up to your Analog input to tell your angle.
http://www.chiefdelphi.com/forums/sh...=potentiometer
You could also do it with an encoder also. You have your starting position call it zero. You count the pulses if you go left or right on the sensor. Then when you want to return you just do the opposite back to zero again.
The easier would be the first option with a potentiometer on the shaft. If you need additional help with programming or something feel free to contact me on IM.
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 13-01-2008, 09:48
Re: Sensor Issues
I may need some help. Thanks for the offer
video issues Charger_07 General Forum 3 11-02-2007 23:53
CPU issues Windward Electrical 3 01-02-2007 22:49
MPLAB Issues jcatt Programming 3 02-02-2006 17:49
Gear tooth sensor issues Nine9cracker Electrical 2 17-01-2006 02:37
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
