Go to Post Teamwork has always gotten us somewhere. - Arefin Bari [more]
Unread 12-01-2008, 18:22
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
pic: The real robot - Week One work
Unread 12-01-2008, 18:24
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: pic: The real robot - Week One work
GAH!! We are still in the design/prototype phase! Awesome
Have you guys thought about the side load on that drive shaft? I do not know much about the super shifters but looks it you should have a bearing block on that thing.
thanks, Vivek
p.s. did I mention the orange belting looks cool?
"we don't build robots, we build people"
Unread 12-01-2008, 20:29
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
will that stuff change shape or turn brittle when it gets cold?
Unread 12-01-2008, 20:37
Kat Kononov's Avatar
Kat Kononov Kat Kononov is offline
AKA: artqny
FRC #2022 (Team IDK)
Kat Kononov is an unknown quantity at this point
Send a message via AIM to Kat Kononov
Is that 4 wheel drive? How are you guys gonna steer it? tank?
Unread 12-01-2008, 22:06
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Looks nice! That looks like a really really short robot......or maybe it's a wide bot.....looking forward to seeing it at LSR!
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 12-01-2008, 23:51
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Nice SuperShifter mounts!
Unread 13-01-2008, 09:01
It is a wide robot so the front to rear is short. It is four wheel drive / tank steer. I do not know the thermal properties of the belting but I don't think that we have a reason to be concerned. It was nice to find the small angle plate for the AM toughbox in the kit as the AM supershifter has the same hole pattern. We needed an additional support so this idea came to mind. We'll look on Monday to see if we can move the plate to the inside of the transmission so that we can more easily get a second cross-brace on there and have a better support for the rest of our electronics package.
View basic product specs for the polyurethane belting.
Looking at the specs specifically for temperature data, I can now say that we should be fine as long as we don't attend a regional in the artic circle
TEMPERATURE RANGE
-22ºF to +150ºF
-30ºC to +66ºC
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 13-01-2008, 09:46
Gdeaver Gdeaver is offline
FRC #1640
If each wheel was drive by a belt from the trans, then a belt failure would not shut down a side. Right now if you lost the belt from the trans to the first wheel, your robot would be stuck spinning in a circle.
Unread 13-01-2008, 10:52
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
cool, the orange belt is sweet...it looks kind of like elastic!? BTW your left wheel should you a bearing block or something because it's tilted
Unread 13-01-2008, 14:15
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
Looks good so far...
A couple suggestions:
1) Extend the shaft of your drive pulley and put a pillow block on the other side. Even though there are two supports in the gear box, you will be putting a lot of side shearing loads onto that axle.
2) Tension: Maybe you want to have a spring loaded tensioner to make sure you have good contact with those belts at all times.
3) Once you have the kit-bot frame set to go, maybe you should weld the pieces together. I would hate to see a bolt or two come loose during the competition.
Good work!
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Unread 13-01-2008, 15:00
Thanks for the many suggestions. By far the coolest thing that we have found with a week's worth of play with this urethane belting is that no tensioning system is needed at all. The elasticity and friction between the belt and the UHMW pulley is terrific. Even when the belt looks slack, it grips the pulley and does not slip. We'll look at the side load issue and may go to the two belts from the drive shaft going to a single wheel as a fail safe idea. Since the belt is under constant tension, is that making the side loads more of an issue then in previous years when we ran the Kitbot and transmissions in very much the same configuration with ansi #35 rollerchain?
APS
Founder FRC 499
Unread 13-01-2008, 20:09
Ross340 Ross340 is offline
It's all food in the food
AKA: Ross
FRC #0340 (G.R.R.)
Team Role: Driver
Ross340 will become famous soon enoughRoss340 will become famous soon enough
any trouble with that stuff slipping?
How thick is it?
What material does it ride on?
Unread 13-01-2008, 20:43
There don't appear to be any as of yet. We'll be giving it a full test this week. It is extremely grippy with the plastic pulleys. The spec sheet linked above quotes friction coeficients for steel as well. This is 'v' belt @ 0.500 width on outside. The belt actually rides on the sides as it doesn't seat on the I.D. of the pulley. This means there are two surfaces gripping instead of one.
APS
Founder FRC 499
Unread 18-02-2008, 07:31
Complete robot after week six.
APS
Founder FRC 499
Unread 31-03-2008, 15:44
Well the real test on this system came in Katy, Texas during the LoneStar regional competition. They gave us fits all weekend long. During hard stops the belts would jump off the pulleys. We increased the tension and even added a flange on the side of the pulley, none of which eliminated the problem. It was very frustrating as we had driven the robot hard on the test field in the shop but nothing matches the punishment of competition. After we were eliminated in the quarterfinals in Texas we began the switch over to #35 ANSI rollerchain and sprockets and never had a problem again with the drive-train. This allowed us to put in a dead-reckoning / closed-loop hybrid mode which could clear 2 - 3 lines depending upon robot traffic.
APS
Founder FRC 499
pic: Our ALMOST COMPLETED ROBOT!!! REAL PICS!!!! L@@K!!! sgsdragons Robot Showcase 13 19-02-2005 14:22
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: Here is the real robot from Team 1313! CD47-Bot Extra Discussion 6 04-03-2003 12:45
Which one is the real Dean? archiver 2001 0 24-06-2002 02:36
6 WEEK CRUNCH TIME = ENOUGH REAL WORLD DEAN-O!!!!!!!!!!!!!!! archiver 2001 33 23-06-2002 22:32
