Go to Post A stack of hearing aid batteries can also read 13v, but they won't run a robot. - Alan Anderson [more]
Unread 12-01-2008, 23:24
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
A Portable Serial Data-logger for the FRC Robot Controller
I just finshed building a cool project to help us debug our code during Hybrid and teleop mode.
I wanted to be able to record dagnostic data from the RC and I didn't want to use wireless because I thought it would also be helpfull during competitions.
I got a cool serial datalogger from Spark Fun and adapted it to the RC Serial Port 2. It only took a single 4 wire cable and simple code modification... Only a couple of hours work.
If you want to get dynamic driving data from your bot... check out the white paper I just wrote...
http://www.chiefdelphi.com/media/papers/2065
Phil Malone
http://www.GEARSinc.org
Unread 13-01-2008, 00:04
Tim Arnold's Avatar
Tim Arnold Tim Arnold is offline
1902 UCF Mentor; 1523 MARS Alumni
FRC #1902 (Exploding Bacon)
Tim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond repute
Send a message via AIM to Tim Arnold Send a message via MSN to Tim Arnold
Question Re: A Portable Serial Data-logger for the FRC Robot Controller
Wow, this is very cool! The writeup makes it look quite simple as you say, but my main question is if you know if the serial communications for this are possible with EasyC.
Unread 13-01-2008, 00:06
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
I asked the question today, whether Easy/C printf output can be redirected to the 2nd serial port.
I looked at the WPILIB documentation, it is dead simple to output to the second serial port - but there is no printf - so you will have to supply your own.
Unread 13-01-2008, 10:19
PhilBot's Avatar
AKA: Phil Malone
I've not used Easy C, but if you can output to the second serial port, then maybe you can use sprintf()
sprintf is just like printf, except that instead of sending text to the "console" it writes the resultant text to a string variable.
So if you declare a char array:
char Buffer[128] ;
And then write your data to that using sprintf..
sprintf(Buffer, "%d,%d,%d\r\n", test1, test2, test3);
Then you can send Buffer to the second serial port.
You need to make sure that Buffer is big enough for ANY single string you want to write out.
Phil.
Phil Malone
Unread 13-01-2008, 10:26
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
This is excellent work!!!
I've had that very same idea for quite sometime, but have never pursued it.
You've beat me to it.!!
Nice job, well done.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
How Can I Program The FRC Robot Controller To Display My Team Number jesusescobar Programming 5 22-01-2007 10:29
What is the FRC Robot Controller Power Consumption amateurrobotguy Electrical 4 02-03-2006 00:23
USB to Serial converter for controller Ryan Collings Programming 10 22-01-2005 13:14
wich fuse should i use for the FRC Robot Controller? or yaniv Electrical 3 18-01-2005 14:50
delta_t data in Robot controller GreenDice Technical Discussion 3 06-01-2002 08:32
