Go to Post I'm not worried about talking to the robot, but I am worried about when the robot starts talking back... - Moros [more]
Unread 08-01-2008, 23:29
marypim's Avatar
marypim marypim is offline
FRC #1899
marypim is an unknown quantity at this point
3DS Max Question: Objects
So it's my first time working with 3DSM, and I haven't figured some things out yet. I tried google this time, but it didn't really work.
So I have some boxes, spheres, etc and they all make up a car. Can I lock them all together so I can move the car as one object? How do I do this?
Thanks
Unread 08-01-2008, 23:41
legomaster3945's Avatar
legomaster3945 legomaster3945 is offline
FRC #0548 (Robostangs)
Team Role: Animator
legomaster3945 is on a distinguished road
Re: 3DS Max Question: Objects
there are multipule ways to do this
one way would be to group all the items together
(that is easyest its under group chose group under that and select the objects u want joined easy enough)
another would be to link them(dont do this it gets messy )
hope that helps
its late and i dont have max otherwise i would show u the path to follow
-billy
Unread 08-01-2008, 23:57
marypim's Avatar
FRC #1899
Wow, thanks
I think I might have skimmed over that menu when I was looking for a button xD
Unread 09-01-2008, 09:29
richalex2010 richalex2010 is offline
AKA: Jake Alexander
FRC #0177 (Bobcat Robotics)
richalex2010 will become famous soon enough
It can be a lot easier to build a hierarchy while you are modeling (it does get messy it you're doing this after modeling).
For example, for your car, you can link all of the parts of a wheel to (eventually, at least) the tire, and the the tire to the axle, and the axle on up. Once the hierarchy is built, you should be able to move the car body, and everything else moves with it. You are also able to independently animate wheels, doors, etc.
If you've already modeled it, and it is complex (if not, you can build a hierarchy now), you can just group it. However, for all future models, you should be building a hierarchy while you model.
-Jake Alexander
Unread 10-01-2008, 14:06
ea6b607 ea6b607 is offline
FRC #2044
ea6b607 is an unknown quantity at this point
if it get confusing, you can always open the scematics view and that will show you how all your parts are linked in a nice littel tree graph thing. It's also nice while your building your hiearchy. grouping can also lead to problems, because if you have something linked to that object with say reactor or slighttracer shadows or what not, and you want to edit your model you have to ungroup it and it will break all your reactor and lighting links to the group.
Cheers!
Unread 13-01-2008, 11:52
Groene07 Groene07 is offline
FRC #0967
Groene07 is an unknown quantity at this point
Does anyone know of a great tutorial to help us do this? This would be a massive help to me, and my team.
Unread 13-01-2008, 12:04
AKA: Jake Alexander
Do the Modeling an Airplane tutorial, in the modeling category from the Autodesk tutorials (go to Start>Autodesk>3DS Max>Help>Autodesk 3DS Max Tutorials, then also get the modeling section from HERE). It has a bit on building the hierarchy, so it should be of some help.
-Jake Alexander
Unread 13-01-2008, 12:39
FRC #0967
Thanks, I get the general idea now!
I was trying to do this with an axle and wheel...how do I get them to turn at the same speed? When I try they rotate, and don't line up. (lego wheel and axle)
Unread 13-01-2008, 12:57
AKA: Jake Alexander
Originally Posted by Groene07 View Post
oops...clicked the button twice.
Can I delete this post somehow?
Click the edit button, then click on delete. Answer yes to anything that pops up as a result.
-Jake Alexander
Unread 13-01-2008, 13:42
FRC #0967
So the best technique to make this robotic arm move would be a hierarchy?
Robotic arm:
Unread 13-01-2008, 13:56
AKA: Jake Alexander
Most definitely, in that case.
All you have to actively animate is the axle, and everything else, below it in the hierarchy, turns with it.
-Jake Alexander
Unread 13-01-2008, 15:56
FRC #0967
Thank you. I understand the entire hierarchy tutorial, but how can I change how quickly one piece rotates compared to another? I'm trying to animate the motor, and axle....but the axle turns at a different rate than the motor piece is turning.
Unread 13-01-2008, 16:56
JRosselet JRosselet is offline
FRC #0188
JRosselet is on a distinguished road
While we're on the topic of hierarchy, I'm in a bit of a rut myself.
The central axle is rotating. While it is rotating, I need it to move in and out the x-axis as seen below.
My problem comes as I imported the model from Inventor, (so it is a mesh) and need the circle to stay a set distance above the edge of the stationary object. So, I would like the circle to be always x unites away from the edge (represented with the line with arrows). Can this be done hierarchically, or must I manually do this through the graph editor?
AKA: Jake Alexander
For Groene07: It shouldn't be. Select the part that is below the other, and see if it already has keyframes (along the time slider at the bottom). If it does, delete them, and scrub through. If that's not the case, I'm not sure what I can tell you... maybe try to post a video (screen capture or rendering, whichever is easier - it doesn't need to look good to be able to tell what the problem is).
For JRosslet: As far as I know, it would require either some clever scripting or manual animating. Manual is probably going to be easier, unless there is a lot you need to do this to.
Something to consider... you only need it to look good from where the camera is. If you don't intend on any shots inside a building, you don't need to model the inside, for example.
-Jake Alexander
Unread 13-01-2008, 19:26
FRC #0967
I have to "joints" set up. The long arm...and rotating hand at the end. (indicated by the orange axle.) I can rotate the long arm....But when I try rotating the small hand, the entire arm rotates in the wrong direction?
edit- Is there an easy way to delete all of the hierarchy to start fresh?
3ds Max question 65_Xero_Huskie 3D Animation and Competition 2 08-02-2006 18:10
cutting pieces of objects in 3ds max stinger 3D Animation and Competition 5 10-02-2005 20:53
Quick 3ds max problm and question Jeremiah Johnson 3D Animation and Competition 5 31-01-2005 21:50
3ds max 6 Bduggan04 3D Animation and Competition 20 03-09-2003 20:37
Help - objects won't move in Max Kevin Thorp 3D Animation and Competition 7 28-01-2003 12:49
