Go to Post Thanks to everyone who made the regional possible - I know my team had a blast and I'm pretty sure most other teams did too. - Steve Howland [more]
Unread 13-01-2008, 11:54
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Gyroscope saturation?
Originally Posted by RyanW View Post
How exactly would I adjust the program to get a reading while in disabled mode? I don't want to waste too much of the hybrid period calibrating my gyroscope, but I'm not sure when else I could set it...Also, how would I know when to stop sampling?
If you're using Kevin's Gyro code from previous years (vs his new mcc18 3.0 code), it should be running anyways, since default_routine() gets called while you are in disabled, it just won't let you set outputs.
If you're using the new code, just put the code in disabled().
Gyroscope Code Kevin Watson Programming 65 01-03-2008 23:46
Gyroscope ADXRS300 of Analog Devices rebekka Technical Discussion 2 07-12-2006 12:36
Stick Saturation Ralph Lambert Technical Discussion 7 20-01-2003 09:24
Gyroscope Orentation Decay D.Viddy Programming 12 13-01-2003 14:43
