Go to Post The manual can be compared to a textbook in school. If you choose not to use your textbook, you are asking to fail classes. - dez250 [more]
Unread 13-01-2008, 12:44
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
IR Problems
I just started playing with the IR sesnor and i have some probelms.
When i enter 'Learn' mode and press a button on my remote control, the COM0 led turns off, and the error led turns on. After that it goes to the COM0 again, i press the same button and once again the ERROR led is on.
Same repeats with COM1, 2 and 3.
Any ideas what should i do to overcome this issue?
I am using a univeral remote controller.
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 13-01-2008, 12:59
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: IR Problems
If the error LED blinks twice, it means that the remote is sending a non-repeating code. If it blinks four times, that means the remote sends a special key-down command code that is sent over and other until its released.
You might want to try removing ambient lighting and a cleaner power supply. We have had the board blink the error LED on one of our power supplies. Right now we've got it programmed just fine off of a 12V battery.
If it keeps erroring out, just try a new code on your universal remote.
Good luck,
Alex
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 13-01-2008, 13:01
Tottanka's Avatar
AKA: Liron Gurvitz
Re: IR Problems
We have used another remote and it's working.
Thanks =]
Unread 13-01-2008, 15:07
feliks_rosenber's Avatar
feliks_rosenber feliks_rosenber is offline
Félix
AKA: Mentor of Teams #2217 & #2669
FRC #2217 (FOMHA & KY Bots)
feliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the rough
Send a message via MSN to feliks_rosenber
Re: IR Problems
At first my team used the remote control from the air conditioner but it wasn't a good idea so we are gonna use universal remote controller.
Visit team 2217 channel:
http://www.youtube.com/profile?user=team2217
2007 Israel Regional GM/Technion Rookie All Stars
Participated in 2007 Atlanta World Championships (Newton Division)
______________________________________________
Visit team 2669 channel at:
http://www.youtube.com/user/team2669
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Problems muy dificil Programming 5 26-10-2005 17:10
Problems- archiver 1999 0 23-06-2002 23:00
Problems, problems . . . archiver 2000 6 23-06-2002 23:00
