Go to Post As in life, the more restrictive the rules, the more creative the 'best' solution will be. - DonRotolo [more]
Unread 13-01-2008, 13:44
cjtenny cjtenny is offline
FRC #2349
cjtenny is an unknown quantity at this point
Send a message via AIM to cjtenny
2349's drive
We'll have the back 8"s (traction, roughtop) driven by 2 CIMs each through an AM toughbox, the front not driven. Chances are, our hurdling device will be mounted on the "back", making it the front. Battery will go on omni side, then, to reduce chance of tipping.
We've built the kitbot chassis part, and are ordering the wheels / extra CIMs / etc.
This took probably 3x as long to model as it will have to build. It was my first time using CAD.
Thanks, SolidWorks!
Edit / Note: These all may be upside down, as we may flip this over for a lower COG / wheelbase... depends on how easy it is to mount the Toughboxes that way, though.
Image one, rendered with PhotoWorks: What we've built so far
Image two, screencapped from SolidWorks because it's "View-->Screen Capture" has bugs in Vista Ultimate (too bad it didn't run nicely in linux):
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
Arcade Drive Anfony VEX 4 08-11-2006 19:46
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Track Drive greenz_gurl15 Technical Discussion 1 13-01-2003 23:30
Drive AAbrams General Forum 4 11-02-2002 17:21
