Go to Post If your heart is racing and you feel a little nervous, then you're on the right side of the alliance station wall!;) - David Brinza [more]
Unread 10-01-2008, 22:24
RedOctober45 RedOctober45 is offline
Mentor - Embedded Software Engineer
FRC #0291
RedOctober45 will become famous soon enoughRedOctober45 will become famous soon enough
Send a message via AIM to RedOctober45
geer tooth sensor - how many will code support?
Using the gear tooth sensor, how many can encoder the code support? I am unsure how many external interrupts exist on this chip...
Unread 10-01-2008, 23:21
Re: geer tooth sensor - how many will code support?
There are six digital input pins which can interrupt the processor. Two of them are very easy to connect gear tooth sensors to and program for. The other four take a bit more complexity in software to use well.
Unread 10-01-2008, 23:38
FRC #0291
Ok, I understand, thanks!
Unread 13-01-2008, 14:33
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
to make things easier, use Kevin's encoder code (kevin.org/frc) and just modify the Phase-B out of it.
How to integrate Gear Tooth Sensor magical hands Programming 0 18-02-2007 17:43
Gear Tooth Sensor? Raikon Kit & Additional Hardware 3 09-02-2007 16:40
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
LabView Gear Tooth Sensor Code SkiRacer LabView and Data Acquisition 2 17-01-2006 03:53
How many will fit? Joe J. General Forum 1 15-01-2004 15:17
