Go to Post why does everyone think im so violent? - Kim Masi [more]
Unread 13-01-2008, 13:11
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
6 wheels with only 2 powered wheels
we are thinking about doing a 6 wheel design with only the two centered wheels being powered. our outter 4 wheels would be the KOP FIRST wheels, and the 2 center wheels would be the 8" performance wheels from andymark. In our design we have made it so that if we decide to power 4/6 or even 6/6 wheels that would be possible. I just wanted to know if any teams have tried anything like this before.
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 13-01-2008, 13:16
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: 6 wheels with only 2 powered wheels
Are you mounting the KOP wheels lower than the treads? You'd end up with a vertical offset of 1.25" between the middle and outer wheels, since the KOP wheels are 6". You'd get a lot of rock with that design.
Also, consider that all the weight supported by a non-driven wheel is pretty much wasted. It's analogous to driving a rear-wheel-drive vehicle in the snow. Without sandbags in the back, it's hard to gain traction.
Hi!
Unread 13-01-2008, 13:18
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
you are going to be sacrificing power/torqu with only 2 drive wheels, but it should move well. I like the idea of being able to change your drive though.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 13-01-2008, 13:24
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
It's an interesting concept, but I think you should consider your drivers before you follow through. While the 2/6 and 6/6 configurations would probably handle the same, the 4/6 is going to have quite different handling characteristics than the other two. If your driver has been training on the 2/6 and she has to switch to the 4/6 config, it's going to throw her off for a while until it becomes familiar. Just something to think about.
Unread 13-01-2008, 13:26
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Why 8" and 6"? What prevents you from using all 6" or all 8"?
Unread 13-01-2008, 13:33
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
We are using 6" KOP on the middle with 6" omni's on the corners. All six will be powered. It turns great and has a lot of pull.
Unread 13-01-2008, 14:18
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
1519 has successfully used center wheel drive in the past. We used the old 12" pneumatic Skyways in the center with "omnis" at both ends - we put 1" flexible pool tubing over the 8"skyways to give them some lateral slip.
Some of the advantages of this drivetrain are:
- very simple to build
- EXTREMELY reliable (our 2006 bot went through 1 regional, nationals, and 5 offseason comps and all we had to do was check the tire pressure
- maneuverable
Of course, you have to consider some of the cons too:
- not as much traction as a drivetrain with more powered wheels (although it is still quite respectable)
- cannot handle a multilevel playing field
You can check out some videos of it at our site
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 13-01-2008, 14:37
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
We used a center aligned drive in Triple Play, and it worked very well for us in that game. (We went 7-2 with it at the championships and were the leading scorer for our side in all but one match.) It does not do well in a pushing match, but we found that this was more than compensated for in that game by the ability to just go around other robots. It was able to spin with a diameter only about 2 inches greater than the corner to corner diamter of the robot. We had sliders and whole thing was only about 1.5 cm off the ground. I wouldn't recommend this as the competition floors are not always completely even.
The one word of caution is that it takes a while to learn to drive well. Using sensors and software to help smooth out the ride was very helpful. As long as you get it done with enough time to practice and calibrate, it can be a good idea.
Sidenote: We are looking at this type of drive this year, as a backup in case our mecanum drive (first time our team has tried it) doesn't work like we hope it will. This also gives twice as many kids a chance to work on a drive train.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 13-01-2008, 15:59
Andrew Nabors
AKA: Andrew Nabors
wow! thank you all for your quick feedback!
i like all the things you guys have pointed out, they have helped me and the team a lot in deciding what we are going to do.
one of the main reasons we went with the 8" wheel in the center is because we can get a little bit more speed out of it. This wheel will be raised 9/10", therefore making it 1/10" lower than the other 6" wheels.
I also forgot to mention that we will be using the andymark super shifter transmissions to power the two center wheels.
Unread 14-01-2008, 10:24
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
We're doing something similar this year:
8" wheels in the center, 6" omnis on the outside. The omnis are dropped down so that the chassis is on a 1/4" of rocker.
All wheels will be powered, even though only 4 wheels will be on the ground all the time. Also, we're using AM Toughboxes instead of the BaneBots transmissions.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 14-01-2008, 12:42
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
One thing that I can see from a flexibility standpoint - if the center wheels are direct driven on 8" then that would work fine as long as you are only driving those 2 wheels. If you then attempt to drive 2 or 4 of the other wheels at 6" diameter (in addition to the center wheels), then you will need to be careful with your sprocket ratios to get the speeds to match (the smaller wheels will need to rotate faster to cover the same distance). Not that it's a big deal but something that you need to be aware of.
Unread 14-01-2008, 13:10
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
why dont you just adjust the height of the wheels by lets say half an inch or maybe even a quarter and using all 8" or maybe even all 6"
that may you wouldn't sway that much
but im not all too crazy about the whole six wheel drive in this years game
ill tell you from personal experience those things turn on a dime and go straight but its not gonna be the fastest way to get around the track
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 14-01-2008, 15:30
Bob Steele's Avatar
AKA: Bob Steele
It looks like you guys are well along the way to a great design.
I think you should try this out on a test bed first... make up a plywood frame and put everything on.
I think you may find the use of the AM KOP wheels in the corners will limit your ability to turn somewhat.
You will find that this is exacerbated when you load your robot towards one side or the other .... say if you have an arm or lift extending out which changes your center of gravity.
In an ideal world... the four outside wheels would have little weight on them and then your turning would be easy.
Since FIRST is most definitely NOT an ideal world... when you put weight on them and try to make a turn they will stick to the carpet when you try to make them move sideways while turning... they stick more when there is more of the robot weight on them.
This is precisely why many of the designs above are using omniwheels in the corners.
I would suggest that if you have a lift or an arm on one side of the robot you consider at least putting omni wheels on that side.
Its a great start... a six wheel robot with the center wheels pivoting can be very powerful and also very agile if you make the right decisions on robot weight loading.
Also remember that if you are going to carry the ball... you may also have additional problems if it is not carried directly OVER the axis of rotation which is midway between the center wheels. This will also lever additional weight onto those outside wheels.
Good luck on your robot!!!
R
Unread 14-01-2008, 17:22
Andrew Nabors
AKA: Andrew Nabors
thank you again for all of your guys' help!
we are finishing up some CAD models today, maybe i can make a teaser or two for you guys!
Unread 14-01-2008, 17:26
Tapoore's Avatar
AKA: Tom Poore
If you would like to try making a prototype of this drive base you could make some cheap "omnis" like the ones we used on this prototype base. We just got cut a slit down a piece of some blue pool tubing (I think it's used as electrical conduit). Then, we just ziptied it around one of the KOP wheels. They aren't pretty, but we used them through at least 10 tournaments with zero problems. Plus they were way cheaper then buying real omnis and worked almost as well for our application.
http://img155.imageshack.us/my.php?image=wheelshq2.jpg
Help with Omni wheels? atowle1236 Technical Discussion 35 15-01-2008 11:07
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
TO much traction??? (ifi wheels or AM wheels) Heretic121 Technical Discussion 9 04-02-2006 12:09
Image Discuss: Wheels- you want wheels - more from team 25 CD47-Bot Extra Discussion 10 07-09-2003 20:33
Wonder Wheels (aka Side Slip Wheels) Scott358 Technical Discussion 4 08-01-2002 12:36
