Go to Post Give me more tools; I’ll use the ones that are most useful for the job. - Natchez [more]
Unread 13-01-2008, 13:58
7-11number1 7-11number1 is offline
ROAR.
FRC #1711 (RAPTORS)
7-11number1 will become famous soon enough
Tracking Elapsed Time
Our team is getting better at programming using MPLAB and I had a question:
1. What is the best way to track elapsed time?
For example, the the main loop running on the RC is fast enough to loop (3) times each time the IR board receives an input then sends out a pulse. We would like to create a timer and ignore any other pulses from the IR board for a 500ms window to prevent processing the same signal (3) times.
I wasn't sure if the RC had an internal clock which could be read and stored into a variable.
Good Luck!
TEAM #1711
Traverse City, MI
Unread 13-01-2008, 14:13
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Tracking Elapsed Time
The PIC has several onboard hardware timers you could use for this, but I think just counting passes through the main loop would be much simpler for this application.
If you really want to use a hardware timer for this, look at this IFI whitepaper. A polled timer should be good enough for your purposes, so you'd setup the timer in your initialization, then you'd start it and pre-load the correct values when you saw a pulse. as long as the interrupt flag is 0, it hasn't timed out and you should ignore pulses.
Unread 13-01-2008, 16:06
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
We've found using loop counters to be very inaccurate in the past. Writing a hardware timer isn't difficult. We've done it several ways, ranging from using someone else's pre-package code, to writing our own routines last year.
See http://www.chiefdelphi.com/forums/sh...ad.php?t=54948 for a previous discussion on the topic.
Unread 13-01-2008, 16:09
cobrawanabe1699's Avatar
cobrawanabe1699 cobrawanabe1699 is offline
That kid with the TIG welder
AKA: Matt, or to those in the northeast, THE BOBCAT!!!
FRC #1699 (ROBOCATS)
cobrawanabe1699 is a jewel in the roughcobrawanabe1699 is a jewel in the roughcobrawanabe1699 is a jewel in the rough
Use the same tpe of system the NHRA uses for ETs. they can handle a 26-foot car at 330 MPH right down to thousanths of a second
BOBCAT OWNS
I done welded me a robot!
TECHNICAL JUDGE:
FLL Bash @ The Beach 2007 Regional Competition
FLL State Championship, CCSU 2007
FLL Bash @ The Beach 2008 Regional Competition
ATTENDING IN 2009:
FIRST Kickoff in NH
FIRST Regional Competition: Washington DC
FIRST World Championships: Atlanta, Georgia
"If it ain't broke, fix it 'till it is."
Unread 13-01-2008, 16:16
We've found that loop counters are accurate enough for almost all applications. One way to make them better is to account for lost radio packets.
unsigned int loop_counter;
void timer(void) {
	static unsigned char prev_packet;
	unsigned char packets;
	if (rxdata.packet_num > prev_packet)
		packets = rxdata.packet_num - prev_packet;
	else
		packets = 256 - prev_packet + rxdata.packet_num;
  loop_counter += packets;
note: code not guaranteed to compile, done off the top of my head.
Camera locked in "tracking", but not tracking geeknerd99 Programming 1 18-02-2007 22:47
Tracking Ghosty Programming 4 16-01-2007 10:53
Time tracking software scitobor 617 Programming 19 26-08-2005 21:21
It's that time of year again!! (No, not The Championship event) Tax Time!! Elgin Clock Chit-Chat 4 10-04-2005 10:59
IR tracking nzj1 General Forum 3 26-01-2004 22:46
