Go to Post The trick is to train the rest of the team to blame electrical instead. - Al3+ [more]
  #196   Spotlight this post!
Unread 13-01-2008, 15:42
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by paulcd2000 View Post
It has been explained how to add encoders to the gyro code, how about the reverse?
Assuming you want to add the gyro code to your project, lets see if I can do this off the top of my head:
1) Add adc.c/.h and gyro.c/.h to your project directory.
2) Add adc.c/.h and gyro.c/.h to your MPLAB project.
3) Add #include "adc.h" and #include "gyro.h" at the top of teleop.c.
4) Add a call to Initialize_ADC() and Initialize_Gyro() in teleop.c/Initialization().
5) If needed, add #include gyro.h to the top of autonomous.c and/or disabled.c
6) Where needed, add a call to Process_Gyro_Data() in the *_spin() functions.
7) Enable the timer 4 ISR at the top of ifi_frc.h.
8) Make sure timer 4 is disabled at the top of timers.h.
9) Add calibration code somewhere like disabled.c/Disabled() (this requires that you use a mode dongle to emulate the field controller, which will put you in disabled mode for a period of time before transitioning to autonomous mode).
10) Do anything else I forgot to mention here <grin>.
11) Compile, test, calibrate your gyro (see gyro.h).
-Kevin
Kevin Watson
http://kevin.org
  #197   Spotlight this post!
Unread 13-01-2008, 16:19
Rindill Rindill is offline
FRC #1329 (VIPRS)
Rindill is an unknown quantity at this point
Okay, I got a makefile working.
# Jeff Holland: 2/26/2005
# Manual makefile to go with Eclipse
# NOTE: enviornment variables must be set to find linker & compiler.
# NOTE: runs with GNU Make. Might also run with Microsoft nmake with tweaks.
# This Makefile will compile any .c file in the current directory and build the
# (PROJECT).hex file you can load in the robot.
# The OBJFILES variable is filled with .o targets using the wildcard
# command and patsubst. The $(wildcard *.c) will retrieve any .c
# file in the current directory and store it in a variable. The patsubstr
# functions is used to convert a file from one format to another. In
# this case each .c file is converted into a .o extension and then
# stored into OBJFILES. This variable is then used to compile each .c file.
# The rule %.o: %.c rebuilds any .o file if the cooresponding .c file has changed.
# In the compile line you will see two variables $@ and $<.
# $@ will match the target and the $< will match the dependency. So, for
# example, $< will contain main.c whenever $@ contains main.o.
# Note: makefiles are counterintuitive in that the rules don't run in the order
# listed in the file, but instead run whenever they are matched. Also be careful
# with tabs and spaces. Rules need a tab (not spaces) before each action.
#RENAME AS NEEDED
PROJECT=RR
#del for windows, rm for unix
RM := del /F
LIB_PATH=".;c:\mcc18\lib"
#MCC18_PATH=c:\mcc18\bin\
LINKER = mplink
CC = mcc18
PICFLAG=-p=18F8722
CFLAGS = -i".;C:\mcc18\h" -nw=2066
DEFINES = -D_FRC_BOARD
#optimization parameters (default = full optimization)
OPT_ENABLE_ALL=
OPT_DEBUG=-Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
OPT=$(OPT_ENABLE_ALL)
#make a list of object files that match all C files
OBJFILES := $(patsubst %.c,%.o,$(wildcard *.c))
COMPILE=$(CC) $(PICFLAG) $< -fo=$@ $(CFLAGS) $(DEFINES) $(OPT)
all: $(PROJECT).hex
#re-link if any object file changed
$(PROJECT).hex: $(OBJFILES)
$(LINKER) "18f8722.lkr" $(OBJFILES) "ifi_frc_8722.lib" /l $(LIB_PATH) /m $(PROJECT).map /o $(PROJECT).hex
# Recompile a file if it's c-file changes,
# OR recompile everything if ANY header file changes
%.o: %.c *.h
$(COMPILE)
#delete all the build files so you can start from scratch.
clean:
-$(RM) $(OBJFILES)
-$(RM) $(PROJECT).hex
-$(RM) $(PROJECT).map
-$(RM) $(PROJECT).lst
-$(RM) $(PROJECT).cod
  #198   Spotlight this post!
Unread 13-01-2008, 18:15
FRC #2429
Originally Posted by Mike Mahar View Post
Is there some reason that you don't reset the sample accumulator to 0 in the first loop?
I just made this change (thanks Mike) and added some additional documentattion to the ADC and gyro code. Link is in message #1 of this thread.
-Kevin
Kevin Watson
http://kevin.org
  #199   Spotlight this post!
Unread 13-01-2008, 18:46
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Kevin
still getting wierd compile errors.....
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "autonomous.c" -fo="autonomous.o" -k -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\mcc18\h\stdio.h:26:Error [1178] illegal declaration of object of type void
C:\mcc18\h\stdio.h:27:Error [1178] illegal declaration of object of type void
C:\mcc18\h\stdio.h:31:Error [1178] illegal declaration of object of type void
Halting build on first failure as requested.
BUILD FAILED: Sun Jan 13 18:44:53 2008
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
  #200   Spotlight this post!
Unread 13-01-2008, 19:14
FRC #2429
Originally Posted by Jon236 View Post
Kevin
Clean: Done.
Send me your code and I'll look at it. Which compiler are you using?
-Kevin
Kevin Watson
http://kevin.org
  #201   Spotlight this post!
Unread 13-01-2008, 19:23
Jon236's Avatar
AKA: Jon Mittelman
It's the ifi_frc_encoder_beta oput of the box....using the 3.10 compiler and 8.0 MpLab
Jon Mittelman
  #202   Spotlight this post!
Unread 13-01-2008, 20:08
FRC #2429
It builds just fine for me. Make sure the tool suite is set correctly and then use the project wizard to rebuild your project.
-Kevin
Kevin Watson
http://kevin.org
  #203   Spotlight this post!
Unread 13-01-2008, 20:33
Jon236's Avatar
AKA: Jon Mittelman
Kevin,
I re-installed 3.10 and it worked just fine!
Thanks for all your work!
Jon
Jon Mittelman
  #204   Spotlight this post!
Unread 13-01-2008, 20:46
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Originally Posted by Kevin Watson View Post
Sounds like a fun project. I would not do my PID calculations in a ISR. Instead, I would set up a timer to fire off at 100Hz and then wait for the timer interrupt flag to go high and then do your PID calculations. The ideal place for this code is Teleop_Spin() and/or Autonomous_Spin(). Let me know if you have any problems.
-Kevin
Interesting. You're suggesting I run another timer at 100hz, and use one to time the calls on PWM() and the other one for timing the calculations, right?
I think I might have a simpler solution. I have the ISR that calls on PWM() to set another flag high (not the interrupt flag), and check that flag in the _Spin() functions. As a result, assuming the calculation runs fast enough, I'll be one cycle behind, which would probably be the case either way. Does that sounds like it could work?
Thanks.
  #205   Spotlight this post!
Unread 13-01-2008, 21:13
Lafleur Lafleur is offline
AKA: Tom Lafleur
FRC #0812
Lafleur will become famous soon enoughLafleur will become famous soon enough
-Kevin
In testing the code on my test system, this change to the ADC.c code made about 1% saving it time...
  #206   Spotlight this post!
Unread 14-01-2008, 01:29
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
-Kevin
I really appreciate what you are doing, and i don't mean to ask for more, but would it be possible for you to create diff/patch files when you release a new version, to make updating our code easier?
  #207   Spotlight this post!
Unread 14-01-2008, 01:37
AKA: Brennan Ashton
FRC #2605 (A2D_16)
Originally Posted by billbo911 View Post
I'm not sure I am following what the question is. If you have a PWM value that is going to be only one of two states, 0 or 255, then just test for one state. For example:
if (pwm03 > 127)
      accumulator ++;
else
     accumulator --;
I chose 127 just for simplicity.
Just as easily, you could test for the actual value.
if (pwm03 == 255)
      accumulator ++;
else
     accumulator --;
I was attempting to understand what the PHASE B was, i now know, and was just expressing how i was going to do it with out it in my specialized case. That code you wrote is exactly what i had described, and what has been in our code for a while now.
  #208   Spotlight this post!
Unread 14-01-2008, 09:57
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
It's nice to know that great minds think alike
I can, with 90% certainty, say that this year we will be using both of the GTS's and one quadrature encoder on our bot. Two for the drive, one for the "ball handler". Now, if the budget allows, we may go with three quadratures. (I hope, I hope, I hope )
  #209   Spotlight this post!
Unread 14-01-2008, 12:36
FRC #2429
Thanks.
My thought was to not even have an ISR and just keep an eye on your 100Hz timer interrupt flag with code located in teleop_spin() and/or autonomous_spin(). Just setup and start a timer, but don't set the interrupt enable bit to one, which will prevent the processor from calling the low priority ISR. Then with code like this in *_spin():
if(INTCONbits.TMR0IF)
// Get encoder counts
// Calculate position/velocity
// Do PID calculations
// Update PWM values
//reset interrupt flag
INTCONbits.TMR0IF = 0;
...you can implement your 100Hz contol algorithm.
-Kevin
Kevin Watson
http://kevin.org
  #210   Spotlight this post!
Unread 14-01-2008, 15:46
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
thank you kevin! i compiled, and everything checks out!
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
