Go to Post No, no, no, it's a fire game. The pool is there in case of accidents. - artdutra04 [more]
Unread 13-01-2008, 16:36
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Field Creation Help
In the team drawings for the field how do you connect PVC assemble A7 with the iron pipe assembly above it?
Unread 13-01-2008, 17:24
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Field Creation Help
We used PVC all the way across, adjusting the PVC pipe sizes to compensate for not having the iron pipe.
We also glued all of the joints, except for two near the center and at the side posts. For those, we used nuts and bolts so that the system can be taken apart and moved if we need to.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 14-01-2008, 01:02
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Screw the #23 black iron upright into the base. Slide PVC assembly A7 over #23. Screw iron cross #34 into place. Along with pipes #24 and #25 and elbow #35. Get everything tightened up. At this point you should have two pillars of iron pipe with a PVC covering. Turn the pipes until the ends of the two columns are close to one another. Install the union #36 and tighten everything up. You should be able to figure out the rest from there.
Christopher H Husmann, PE
"Who is John Galt?"
Anonymous upload/download creation help Dillon Compton Website Design/Showcase 7 23-04-2006 20:06
#define creation NASAbound1636 Programming 3 02-02-2006 23:40
Forum Creation help CraigHickman IT / Communications 9 22-07-2005 00:13
Robot Creation Help GregTheGreat Technical Discussion 5 23-10-2003 12:09
mini-field help... archiver 2001 6 23-06-2002 22:23
