Go to Post That is why I think that the Chairman's Award is better. You can have a great robot and something weird happen to your alliance and you are out. If you have a great team and win the Chairman's Award you are in the Hall of Fame forever. - WEHickok [more]
Unread 13-01-2008, 20:27
joshyboy9987 joshyboy9987 is offline
FRC #0706
joshyboy9987 is an unknown quantity at this point
Re: Filtering out Vibration while using a KOP Accelerometer
Thanks for the advice. What do you guys think about taking the derivative of the acceleration and if it's too high just throwing the data over again. (I guess that's kind of a filter too, in a way)
I don't use a timer-based interrupt as I first planned, but am instead using the timer function in easy C to measure the time difference between calls... The timer is then reset to 0 to start the next time period.
I'll post our data a little later, I don't have it on my computer, it's on the robotics one.
I've read the spec sheet, but if I end up using a filter as they suggest, won't it take out things like the robot crashing into the wall and stuff like that. That would change the acceleration really fast. I mean, I can't assume I'm not going to hit anything in autonomous (hybrid) mode.
What bandwidth would you suggest?
EMI Filtering Mike Betts Electrical 1 06-03-2007 15:38
Using camera PWM out Cuog Programming 2 28-11-2005 14:17
Hall effect sensor Filtering magical hands Programming 5 13-02-2005 11:23
Content Filtering FRANK(WGH) IT / Communications 1 23-10-2004 09:21
Using Accelerometer with '04 controller sanddrag Control System 4 20-02-2004 12:18
