Go to Post Everyone should go look at the baby pics….it will make you feel better. - wendymom [more]
Unread 13-01-2008, 21:02
Bohalin Bohalin is offline
mentor
AKA: Sean
FRC #0157 (Aztechs)
Bohalin is on a distinguished road
under overpass
pretty simple question concerning my team, can you go under the over pass and push out from the bottom, or does it have to be pushed out from the back, as shown by the robots in the animation?
Unread 13-01-2008, 21:04
1619Aaron's Avatar
1619Aaron 1619Aaron is offline
FRC #1619
1619Aaron is an unknown quantity at this point
Re: under overpass
You can push a ball off from under the overpass.
Unread 13-01-2008, 21:14
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
Re: under overpass
You cannot reach back and grab the ball once you have passed the finish line. This would violate the "you cannot cross a plane you have already crossed" rule (i don't have my manual handy, otherwise i'ld give you the number and exact wording). The only way around this is to hit the part of the ball that extends past the finish line (its not a big target). It is much easier (and less likely to break a rule) to hit the ball from underneath (which is legal) or grab it from behind.
Unread 14-01-2008, 11:25
mentor
AKA: Sean
FRC #0157 (Aztechs)
Re: under overpass
thank you very much for the help guys!
Unread 14-01-2008, 11:47
gdawg116's Avatar
gdawg116 gdawg116 is offline
FRC #0116 (Epsilon Delta)
Team Role: Student
gdawg116 is an unknown quantity at this point
Re: under overpass
It is legal for you to reach under and then across the line, then come back and hit the ball as long as part of your robot stays in the same quadrant as the overpass.
Hurdling using the overpass robogeek753 Rules/Strategy 40 20-01-2008 17:02
Arena Assembly, Overpass ... DWG Error? Ziaholic General Forum 4 10-01-2008 00:34
Carrying the ball under the overpass but across the finish line BaldGuy Rules/Strategy 13 09-01-2008 14:53
rule question on scoring above overpass Robo_Coyote Rules/Strategy 35 08-01-2008 09:03
Height of overpass Evert General Forum 8 07-01-2008 14:11
