#31
Re: Help, I'm a world class computer programming genius yet I'm totally lost.
You said you've worked for Electronic Arts? What's it like, as a game programmer? I've done some fiddling around with the Source Engine code, and I am trying to get a game project off the ground. Any tips? Things to watch out for? Reasons why Wisconsin is not a good place for game programmers? Last edited by ShotgunNinja : 13-01-2008 at 18:07. |
#32
Re: Help,....
I went to the Microchip site and downloaded the zip file with MPLAB 8.01. No errors. I tried installing it. Also no errors and the application launched just fine. If you're getting CRC errors, I wouldn't use it. You should have gotten a Disc in the FIRST kit of parts and I'd advise finding that instead of downloading from the Microchip site. ALSO, in previous years, we were warned to only use MPLAB ver 7.20 and C18 Compiler ver 2.40. Not sure if that still applies.
Anyone else know? Anyway, I'd really recommend using the kit of parts disc since it will have the correct version and you shouldn't have the CRC problem using that. I looked at Easy C. last year... I agree with you. I think a program like easy C is needed, but right now, Easy C could stand a little tweaking. Just my opinion. Steve Quote:
#33
This is a good reference to the odd PIC things along with the current datasheet on the 18F8722 that you can download from Microchip...
#34
The other thing to remember is that there are a lot of good resources out there for new teams to use. You're visiting one of the better ones (ChiefDelphi). Look at the whitepapers. Read the forums. Ask questions. We're here to help you out. There are few problems you can run into where someone here can't help you out, and quickly. |
#35
Re: Help,....
Re: Help,....
If I don't use the version the beta version he has posted, what version am I supposed to be using? Can someone give me a link? Right now I am up to speed programming the VEX using the sample code that comes with it. Is there completely different sample code to be used as a starting framework for the FRC controller? How can I experiment between the two systems interchangeably? We don't have anything at school up and running to let me test code on the FRC so for the moment I am limited to the VEX system. Thanks, John |
#37
We (Team 1296) are having problems as well. But only on one of our computers. It's giving us an error involving a .cof file but seems to be creating the .hex file anyway. We not far enough along to determine if the .hex file is any good. Any suggestions would be helpful.
Thanks, C |
#38
We'd be able to give you better help if you quoted the actual error. But my guess is that you're running into a known issue involving long path names. The part of the link process which creates the .cof file doesn't deal well with the long name that comes from deeply nested folders. The usual advice to fix the problem is to put your program directory somewhere close to the root, like C:\ROBOT.
Or you can just ignore the error, because you don't actually need the .cof file in order to load the program into your robot. |
| AHHH! I'm a lost newbie! I need help! | lkdjm | Programming | 8 | 28-01-2006 08:41 |
| i'm in the charleston area, and i'm looking to help out a team near here... | dickymon | General Forum | 2 | 05-08-2002 16:40 |
| OK...so I'm totally out of the loop... | Markfuscius | 3D Animation and Competition | 8 | 03-02-2002 02:39 |
