Go to Post "We'll fix that in programming" - EStokely [more]
Unread 13-01-2008, 19:51
team877's Avatar
team877 team877 is offline
FRC #0877 (Cub Robotics)
team877 is an unknown quantity at this point
Controller Speed programming
I want to be able to have my robot only going so fast when the variables are between like 127 to 200 but when the variable exceeds 200 it returns to beening the normal variable. How can I do this in easyC?
Example:
-if pwm1 is between 127<200 set it to 150
-but once pwm1 is < 200 go back to equaling its correct variable
Unread 13-01-2008, 20:02
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Controller Speed programming
not sure about easyC, but the code woud look like this:
if((pwm1>127) && (pwm1<200)){
pwm1=150;
else if(pwm1>200){
pwm1=pwm1;
the last "if" is somewhat unnecessary, but i put it there to show you. i'm not sure, but in easyc can you still edit the actual code? if so, this should work.
PS
i dont use easyC because it has the word 'easy' in it
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
if(pwm01 < 200 && pwm01 >127)
pwm01 = 150;
else if(pwm01 > 200)
pwm01 = p1_y
There is Else and ElseIf blocks under Program Flow
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 14-01-2008, 00:35
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
The above two examples don't look like they will work... this code should work copied and pasted (assuming you want your Port 1 joystick to control pwm01):
if(p1_y > 127) {
  pwm01 = 150;
if(p1_y > 200) {
  pwm01 = p1_y;
if(p1_y < 127) {
  pwm01 = 104;
if(p1_y < 54) {
  pwm01 = p1_y;
What place are we at? ... TODAI!
Unread 14-01-2008, 00:56
Gamer930's Avatar
AKA: Justin
Originally Posted by JohnC View Post
This code should work copied and pasted (assuming you want your Port 1 joystick to control pwm01):
if(p1_y > 127) {
  pwm01 = 150;
if(p1_y > 200) {
  pwm01 = p1_y;
Just a word of wisdom: If you are doing consecutive if statements comparing the same variable to numbers it is almost always better to use multiple ElseIf.
Why? With If statements the processor has to check each condition to see if it is true or false. In an if/if else statement once condition is true it skips all other. This will allow you programs to execute faster.
Won't notice much of a difference in this programming but if you start getting longer If statements with huge conditions you will start noticing the speed difference
Speed Controller Code ND4SPDLSC Programming 2 18-02-2006 21:48
Speed Controller Data viewtyjoe National Instruments LabVIEW and Data Acquisition 4 02-02-2006 16:05
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
Speed Controller Megas_xlr Control System 3 18-01-2005 15:41
Speed Controller Megas_xlr Electrical 3 18-01-2005 15:41
