Go to Post Being rude is easy. Being a compassionate human being takes work. - Joe Johnson [more]
Unread 14-01-2008, 08:11
Vanquish Vanquish is offline
Rookie Year: 1980
Vanquish is an unknown quantity at this point
Compiler Error
When I try to compile my code it gives me this error. I've tried a few things and searched around for a few days and nothing seems to be working. Any ideas?
Errors Found.
UTIL LIB.ASM
Errors: 265
Warnings
Reported: 285
Suppressed: 0
Reported: 0
Supressed: 0
Lines Assembled: 926
Unread 14-01-2008, 08:21
cliff451 cliff451 is offline
FRC #2077 (Kettle Moraine Robotics)
cliff451 is an unknown quantity at this point
Re: Compiler Error
Unless you're writting assembler, I think you may be using the wrong linker. Make sure you have the C18 stuff installed and configured. We had this problem last year.
Unread 14-01-2008, 16:36
JonathanLKS JonathanLKS is offline
Code::Blocks
FRC #0610 (The Coyotes)
JonathanLKS will become famous soon enough
Send a message via MSN to JonathanLKS
Re: Compiler Error
Also, make sure that if you installed mplab before c18, that you set mplab to use the one you installed under Projects > Select Language Toolsuite.
We've had that problem more than once in the past.
Team 610 [ Co-Leader | Head Programmer | Webmaster ]
We're attending: Greater Toronto Regional, San Diego Regional, Championship
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
compiler error SgtMillhouse648 Programming 5 05-02-2007 15:21
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
WEIRD compiler error Rickertsen2 Programming 7 05-02-2005 14:09
Confusing Compiler Error UrsaMNet Programming 2 28-10-2004 14:32
