Hi all,
For a project I am doing seperate from FRC, i am making a mini darpa rover. The question i have is, how do i take a deg,min,sec value (ex. 172*34'53") and convert into decimals in programming. By hand it should be 172 + (34/60) + (53/3600). But alas I cant do that so easily in EasyC. Any suggestions? ![]() |
Re: Converting Data EasyC
Put this into a user code block
answer = 172 + (34/60.0) + (53/3600.0); When you do .0 it does Decimal Division instead of integer division 34/60 in integer division is 0 so you were doing 172 + 0 + 0 |
You could also save the CPU a tiny bit of computational exertion by turning minutes into seconds first, adding the seconds, then converting the result to fractional degrees when you add things up at the end.
34*60 + 53 = 2093 172 + 2093/3600.0 = 172.581 |
but i wont know the value to begin with. it will come to me in the form of x*y'z" but the number could be anything
Is that going to be given to you as 3 separate variable?? Then you can just insert those variables into the formula. answer = Variable1 + (Variable2/60.0) + (Variable3/3600.0);
If you are given a string in that exact format then you would have to use a "Tokenizer and Tokens" not sure how you would do that in C or EasyC. If you would like how to do it in C++ send me an e-mail and I will send you some sample code. |
| Converting EasyC Tracking Code into MpLAB | Ultima | Programming | 5 | 02-08-2007 09:38 PM |
| Question about default camera data table in easyC pro | itsme | Programming | 1 | 01-16-2007 01:57 PM |
| Kickoff easyC workshop integrated into EasyC help file | Dan Larochelle | Programming | 0 | 01-11-2006 06:12 AM |
