Go to Post Sometimes the team really needs the kid, and sometimes the kid really needs the team. - Taylor [more]
Unread 13-01-2008, 13:43
7-11number1 7-11number1 is offline
ROAR.
FRC #1711 (RAPTORS)
7-11number1 will become famous soon enough
Extending IR board connector wires
I assume everyone will be putting the IR received near the top of their robot. What type of connectors are you doing to use? Possibly DB9 (Serial) or would an RJ-45 network extensions? Running multiple PWM cables to the IR board doesn't seem like a good idea.
I'd like to put this connector either inside the tubing of the robot or protected by the robot PIC controller due to the potential for knocking off loose pieces in this years game.
Good Luck!
-Michael
Team Mentor: #1711
Unread 13-01-2008, 14:59
Re: Extending IR board connector wires
The IR decoder board has a ten pin ribbon cable connector. It came with a ten pin ribbon cable. I don't see a reason to use anything other than a ten pin ribbon cable to connect it. That's how we're doing it.
At the other end of the ribbon cable, we have a board with another ten pin ribbon cable connector, a pair of FAST-ON connectors for power, and spots for two PWM cables to plug in and carry the four digital signals to the RC. For the final wiring, I think we'll forego the extra connectors and solder the power and signal wires directly to that board.
Unread 14-01-2008, 03:33
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
Hi Alan -
Do you happen to have part numbers for the 10-pin ribbon cable connector and header? Not being well-versed in electronic parts, the number of potential matches out there seems overwhelming.
Thanks!
Unread 14-01-2008, 03:58
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Hi Michael,
We also use the 10-pin connector, but we have it wired differently than Alan described. Our wiring guru wired one three-pin ("pwm") cable to the power, ground, and first signal lines, and another three-pin cable to the second, third, and fourth signal lines. The result is only using two three-pin cables while getting all the capabilities (the cables are connected to the RC in somewhat of an L shape - the first cable connects regularly to a digital IO pin, and the second one spans the next three signal pins afterwards).
Hope this helps.
Unread 14-01-2008, 07:23
itsme itsme is offline
FRC #2217 (FOMH)
itsme is an unknown quantity at this point
Originally Posted by sumadin View Post
Hi Michael,
Hope this helps.
Liked your method.
just a small question: doesn't the IR board need between 7-15 volts?
Because from what I know the digital I/O brings only 5 volts, and you connected the power and ground to the digital I/O port.
2007 Israel Regional GM/Technion Rookie Allstars
Participated in 2007 Atlanta World Championships (Newton Division)
Unread 14-01-2008, 09:24
http://www.newark.com/jsp/content/pr...125&page=68 1
The Amphenol 812 and 816 series look good. I think the parts I scrounged are actually made by 3M.
That's exactly how I wired the signal connectors, with the exception of the power. The RC digital pins only supply +5v, which is why my connection board has separate FAST-ON tabs for +12v from the circuit breaker/distribution panel.
Unread 14-01-2008, 10:40
JimS JimS is offline
JimS is an unknown quantity at this point
I am confused.Do you need a seperate power supply for the IR board and do you connect the gnds together between the robot controller and the IR board and also which inputs to use digital or analog? For the inputs to the RC.
Unread 14-01-2008, 10:52
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Cool Re: Extending IR board connector wires
I am modifying Chief Delphi Team#47 IR Board to accept separate power from robot distribution board (2 wires, +12 V and ground). As such, we will be gluing a small, two pin, connector to the board. Between the new connector and the existing 10 pin connector pins for power (pins 1 & 2), we will be soldering an inline 1N4007 diode for reverse battery protection. The new connector will also have add a small wire from the ground to ground (pins 3 & 4). Since the system will be connected to the 12V system, the 0.7 volt diode drop will not be an issue.
I will try to post a digital picture after the work is completed.
I haven't decided what to do yet about the 4 signals that need to come from the IR board to robot controller( 2 Pwm wires, one with 3 signals, the other with one signal and ground OR 4 PWM wires, one for each signal/ground).
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 14-01-2008, 21:49
ROAR.
FRC #1711 (RAPTORS)
Hi Michael,
Hope this helps.
Does this leave the grounds pins on the digital I/O floating or are they connected back to ground? I thought about doing something similar to save cable, but I thought I would just keep it simple (KISS) and use 4-pwm cables. This will reduce the probability of the kids hooking it up wrong.
what is the four pin white connector for on the ir board ? Smaug Electrical 2 10-01-2008 23:37
Extending objects Booger Inventor 10 14-07-2006 13:04
height violation while extending gondorf Rules/Strategy 13 20-01-2006 08:33
Extending a cantilevered drive shaft. Madison Technical Discussion 18 04-11-2005 00:27
pic: Vex before extending Not2B Extra Discussion 5 17-04-2005 22:01
