Go to Post God bless the camera. That's all I gotta say. - Bharat Nain [more]
Unread 14-01-2008, 01:18
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
Re: Filtering out Vibration while using a KOP Accelerometer
Your calculations look very wrong, i would check them first.
<R68> is what i was referring to, the beginning makes it sound like they are not allowed, because they are not COTS. But if all of the components are COTS and you put them on the PCB is that OK?
Unread 14-01-2008, 01:36
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Let's look at R68:
Originally Posted by <R68>
Additional electronic components for use on the ROBOT must be either COTS items or assembled from COTS items. Additional electronic components include any object that intentionally conducts electricity, other than Innovation First Inc. relays and speed controllers, wires, connectors, solder, and fabricated printed circuit boards.
So as long as your custom electronics is either COTS (such as an encoder) or assembled from COTS items, it's allowed. A separate PIC, resistors, capacitors, PCBs, etc, are all examples of COTS items which can be assembled to your own circuit.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 14-01-2008, 01:41
jleibs's Avatar
jleibs jleibs is offline
Computation and Neural Scientist
AKA: Jeremy Leibs
jleibs is a glorious beacon of lightjleibs is a glorious beacon of lightjleibs is a glorious beacon of lightjleibs is a glorious beacon of lightjleibs is a glorious beacon of light
Send a message via AIM to jleibs
As for data. I guess one question I have is: what motion (if any) was occuring while this data was recorded.
The next question is how to interpret your accelerometer values, which are in the range of 475 to 569 or so. How does this relate to millivolts coming out of the accelerometer? Sorry, I havn't played with the controller in a while... and when I did, back in 2002... well... everything was different
Anyways, according to the Sensor Manual, it would appear that horizontal orientation under no acceleration should be outputting 2.5 volts.
According to the Data Sheet, it would appear that the 0g corresponds to 1.65V given a 3.3V input. I think first is driving it with a 5V input. So a 0g output of half of Vs seems to be self consistent here.
So the first thing we want to verify: is the meaning of your numbers there somehow consistent with the ~2.5V +/- 1.7V that we expect to see from the output of the device?
Unread 14-01-2008, 01:45
AKA: Brennan Ashton
FRC #2605 (A2D_16)
Originally Posted by ay2b View Post
Let's look at R68:
my concern stems from the fact that I cannot come up with something that would be in violation of this rule if it is not a drive circuit which are explicitly prohibited. So if I fully design my own integrator and PCB, then I am ok?
Unread 14-01-2008, 08:05
Originally Posted by jleibs View Post
The next question is how to interpret your accelerometer values, which are in the range of 475 to 569 or so. How does this relate to millivolts coming out of the accelerometer?...So the first thing we want to verify: is the meaning of your numbers there somehow consistent with the ~2.5V +/- 1.7V that we expect to see from the output of the device?
The RC's analog inputs have ten bits of precision. That gives results from 0-1023 for a voltage from 0-5 volts. A value of 475 translates to about 2.32 volts, and 569 represents about 2.78 volts.
Unread 14-01-2008, 08:12
Try a Kalman filter. There is source code to some optimized versions floating around on the internet. (The full filter is a bit labor intensive.) This filter was designed to read noisy signals and make estimates of true value based on it.
http://en.wikipedia.org/wiki/Kalman_filter
Unread 14-01-2008, 08:22
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Originally Posted by joshyboy9987 View Post
won't it take out things like the robot crashing into the wall and stuff like that. That would change the acceleration really fast. I mean, I can't assume I'm not going to hit anything in autonomous (hybrid) mode.
Hey, that's a safety feature we're having in hybrid mode! We're using one of the programmable comparators to detect (and generate and interrupt) if we get a G-spike indicating a crash (a lot like a car with airbags) and in the event of a crash will kill all the motors to protect the robot. Now if we can just get it to call OnStar...
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 14-01-2008, 08:24
AKA: Alex
Hmmm... The design team is gonna have a fit if I tell them to put an extra wheel on the robot, maybe I'll just make 'em deal with it.
uhhhhh..... just put an encoder on one of the wheels you already have? I realize this can slip, but its probably a better probability of it working than an accelerometer with error squaring... eh... i mean double integration.
-q
Unread 14-01-2008, 11:34
jleibs's Avatar
AKA: Jeremy Leibs
First of all, Kalman Filters are great
Second of all, the rest of this post will likely sound like non-sense unless you've read a couple articles in Kalman Filters. If you think you're interested in Kalman Filtering, this is a good place to start.
Now onto what I was going to say: I've never had a Kalman treat the accelerometers as direct measurements in a nav system before. There are a couple reasons for this. Keep in mind, I use a full 6DOF system where all of this is more complicated. For one, it requires running the Kalman faster than we want to (at the full 400Hz IMU rate). Additionally, doing so requires the linearization of a fairly gnarly prediction function (since the prediction function is doing an implicit double-integration).
Finally, and I think this is the most important one: if your state vector includes acceleration and you are Kalman filtering your acceleration. You need a MODEL of how you expect your acceleration to change from one time-sample to the next. It's comparing this prediction to what you actually measure that allows a Kalman to function well. You have no means of acquiring such a prediction, especially when you want to measure things like crashes and bumps (outside the scope of your controlled values). So basically, to tune your Kalman to reflect the unpredictable nature of your accelerations, the process noise will have to be high enough that very little smoothing will actually happen.
What we tend to do is leave acceleration out of our state vector. We track position, orientation, and velocity inside the Kalman. We then integrate the accels/gyros using the inertial nav equations essentially as part of the prediction phase, and use this to update our predicted position/orientation/velocity values. Then, we use the Kalman measurement update to incorporate additional sensors such as GPS/IMU and correct these terms.
Calibrating and working out bugs in this kind of system is the kind of nightmare that can take an experienced engineer months (or years) to get right. At work, the Kalman Filter we use for our nav system has a state vector with 150 elements in it. Needless to say, it is still being debugged.
But you guys are working in 3DOF and I expect the problem is likely more tractable in that case. Maybe I'll review the equations when I get a chance this afternoon.
Where a Kalman would really shine is fusing measurements from your accelerometers with measurements from your shaft encoder or other sensors.
Anyone, please feel free to contact me if you would like to discuss Kalman filtering in more details.
Unread 14-01-2008, 23:20
AKA: Brennan Ashton
FRC #2605 (A2D_16)
Some people might find this article of interest.
http://www.freescale.com/files/senso...ote/AN3397.pdf
Unread 14-01-2008, 23:36
jleibs's Avatar
AKA: Jeremy Leibs
Definitely a great starting point for anyone looking at doing this. Thanks for the great find, comphappy!
Unread 17-01-2008, 23:15
joshyboy9987 joshyboy9987 is offline
FRC #0706
joshyboy9987 is an unknown quantity at this point
Yeah, my calculations were off a bit... I forgot to keep track of the stupid velocity constant when I did the first integration... Now the data is better, but still bad... I think we might go with the encoders... We even shock mounted the accelerometer, and that didn't help all that much. (Magnetic shock)
Unread 17-01-2008, 23:17
AKA: Brennan Ashton
FRC #2605 (A2D_16)
you may consider low pass filtering out the freq range from the motors and/or compressor.
A2D Solving the Imaginary Error Function...
Unread 18-01-2008, 07:42
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
I looked at the data in the spreadsheet. I plotted the dx values and the dy values (I assume these were the result of double integration and represented position). Each seems to have a recognizable trend. If this roughly corresponds to the movements you were applying to the robot (you didn't say), I'd be encouraged that the data could be useful. Sure, it's a little fuzzy. The trick is to filter out the fuzzyness without delaying the data so much that it's no longer useful.
If you need instantaneous location to within an inch, it's probably not going to be useable. But if you just need to know if you are probably past the wall and should turn left, it might work.
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 21-01-2008, 02:55
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Hi, I'm currently trying to decide between using wheel odometry and a double integration of accelerometer data. So this is a very interesting conversation!
One thing that I've failed to see is any mention of the gyroscope data used in conjunction with the accelerometer data. I see this as important because the robot's frame of reference translates and rotates with respect to the absolute coordinate frame of the field. Pretty much what I am saying is that the x and y coordinates of the accelerometer won't always remain parallel to the x y axes of the field therefore the orientation of the robot must also be monitored. Has anyone considered this as a probably source of error? I might've missed something, but there is my two cents!
windell
#2477
EMI Filtering Mike Betts Electrical 1 06-03-2007 15:38
Using camera PWM out Cuog Programming 2 28-11-2005 14:17
Hall effect sensor Filtering magical hands Programming 5 13-02-2005 11:23
Content Filtering FRANK(WGH) IT / Communications 1 23-10-2004 09:21
Using Accelerometer with '04 controller sanddrag Control System 4 20-02-2004 12:18
