Go to Post We make ourselves better by lifting others and standing on their shoulders, not by knocking them down. - Taylor [more]
Unread 12-01-2008, 17:32
xrabohrok's Avatar
xrabohrok xrabohrok is offline
hunter of errors
FRC #1208 (The Metool Brigade)
xrabohrok is an unknown quantity at this point
Can't find frame generator
On all tutorials, when I right click on the assembly toolbar, I'm supposed to see the frame generator option displayed. Instead, all I see is "display text with icons". What am I doing wrong?
"It's programming's fault" may be a viable excuse for just about everything, except the robot falling apart.
It will 'cause it can!
constants aren't. variables won't.
Unread 14-01-2008, 12:11
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: Can't find frame generator
Assembly Panel Bar drop down.
Also,
If the frame profile you need is not available there is now a custom editor at http://labs.autodesk.com for adding your own profiles. I had trouble understanding the instructions and wrote up my own tutorial if you are interested.
Name:	Frame Generator.jpg
Unread 14-01-2008, 16:11
grsnovi's Avatar
grsnovi grsnovi is offline
Autodesk Inventor Team - Portland,
AKA: Gary R Smith
FRC #2542
grsnovi will become famous soon enough
You might want to double-check that the Frame Generator add-in was installed/loaded. Click on the TOOLS menu and select ADD-INS... find Frame Generator. It should say: "Startup/Loaded" in the right column.
We can't find our bandanas! Carol General Forum 6 17-12-2007 15:42
Can't find CMUCam2 demo.llb railerobotics Programming 41 06-02-2006 18:40
Can't find .h files pmzq Programming 2 24-01-2006 01:03
Can't find CD? Trinora 3D Animation and Competition 2 10-01-2004 14:47
Can't find Agenda's on FIRST site.... archiver 2001 1 24-06-2002 00:18
