Go to Post A poor robot with good drivers playing on good strategy will whomp a good robot with poor drivers running on poor strategy any day. - henryBsick [more]
Unread 14-01-2008, 12:26
Re: Beware of R16 your robot design may be too big.
Originally Posted by ALIBI View Post
Bumpers (R08) are part of the robot (R13) and will be considered in the measurement if located on the robot where the 80" horizontal dimension (R16) maximizes. You can maximize the room available for your manipulator by leaving the bumpers off the opposite side. Right now you can do that without breaking any rules as long as any parts of your robot located within the bumper zone that are not covered by bumpers are within 10 degrees of vertical (R19). In addition, all bump to pass signals (G38) must be made with or against a standard bumper and inside the bumper zone. My guess is that when a team leaves the bumpers off to maximize the 80 inches, it will most likely be what becomes the rear of their robot. In order for another team to signal them to pass, the signaling team would only be able to signal if it had bumpers on the front of its' robot (doesn't make sense to signal from the side, you are all ready past them). At the same time, due to other types of manipulators, I can easily see teams that will leave bumpers off the front of their robots which will make it difficult to signal to pass a robot that does not have bumpers on its' rear. I realize that these are all design decisions and tradeoffs are necessary. You can build a succesful robot within these limits.
It seems like R16 (80" cylinder) and R08 (standard bumpers) are un-necessarily opposing eachother. R08 encourages teams to maximize their use of bumpers and R16 seems to discourage the use of bumpers and may make it more difficult to comply with signaling to pass. Another benefit to bumpers is the protection they provide. You could end up with a lot of exposed hard corners on the rear of many robots.
My ramblings have lead me to wonder whether or not R08, R13 or R16 should be modified to somehow leave standard bumpers out of the requirements of R16. Does anyone else see any wisdom in doing that? If a team has all ready decided to leave the bumpers off to maximize their 80 inches, what harm would changing the rules to allow them the opportunity to add bumpers be? I realize that there may be teams that designed to include bumpers and their manipulator to comply, but wouldn't they like to get another couple inches anyway?
I believe that ALL parts of the robot within the bumper zone must be within 10 degrees of vertical. (And the rule is 2/3 of the perimeter is required to be bumpered.) I don't see where you get that you must have bumper protection to signal to pass, just that you must contact within the bumper zone or with a Trackball.
There are ways to maximize coverage and still maximize the amount of cylinder still available...
It wouldn't be a bad idea to have the bumpers excluded, but that makes the refs' job a bit harder. Bumpers can give a nice easy reference.
Originally Posted by AndyB View Post
Does anybody recall any penalties handed out for this rule last year?
Yep. One or two teams at L.A. were measured post-match after accidental ramp deployment. At least one didn't pass.
What's your robot design? NeoRyu777 General Forum 19 10-02-2006 17:51
So your original robot design was..... LightWaves1636 General Forum 23 05-02-2006 03:36
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
Beware of spending too much time in Chief Delphi Forum! Ken Leung Rumor Mill 42 21-05-2003 18:22
Size of the field: too big? too small? archiver 2000 5 23-06-2002 22:44
