Go to Post I firmly believe that - those [GDC] committee members I have met, even briefly, certainly have a passion for what they are doing and want to give teams and students the best possible experiences. - GaryVoshol [more]
Unread 13-01-2008, 22:36
Lafleur Lafleur is offline
AKA: Tom Lafleur
FRC #0812
Lafleur will become famous soon enoughLafleur will become famous soon enough
Data Smoothing
Here is a bit of code to use the Exponential moving average (EMA) function for data smoothing. I find it much superior to that of a straight average because it favors newer samples, making it more responsive. Also it requires one to save only one value between calculations.
To use, call the EMAweight function with the number of samples that you want to smoothing over, it will calculate a weight factor for the EMA function.
call EMA with the oldvalue, newsample and the weight
here is a reference for EMA:
http://www.esignal.com/futuresource/...tudies/emi.htm
//prototypes
float EMA (int, int, float );
float EMAweight (float);
// how to use
w = EMAweight (30.0); // set weight
xEMA = EMA( xEMA, newsample, w); // old, new, weight
// Ema routines
float EMAweight (float samples)
return (2.0 / ( 1.0 + samples));
float EMA (int prevEMA, int newVALUE, float weightx)
return ((weightx * (newVALUE - prevEMA)) + prevEMA);
Unread 14-01-2008, 10:17
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Data Smoothing
Nice. We've stuck with arithmetic moving averages in the past since they are fast and can be implemented in pure integer math, but it's nice to see someone using this and posting sample code.
Unread 14-01-2008, 13:08
AKA: Tom Lafleur
FRC #0812
Re: Data Smoothing
You can use this with integer math with changes to the math lib.... or use scaling on the weight ratio and final EMA
Unread 14-01-2008, 22:06
Jared Russell's Avatar
Taking a year (mostly) off
Re: Data Smoothing
Second (and higher) order IIR low pass filters have responses similar to this one.
Historical data Andrew Schuetze General Forum 0 15-05-2006 07:42
Data Communication coreyk IT / Communications 4 02-05-2005 19:09
Team Data Katy Scouting 3 02-04-2003 15:17
Match Data Jack Scouting 0 08-03-2003 16:49
