Go to Post However, I do expect something truthful to come out of some of Dave's posts. - Karibou [more]
Unread 14-01-2008, 14:46
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Q&A response - new interpretation of R16
There is a definitive answer, but it's a bit hard to understand, apparently
If your measure from the end of your robot arm to either end of the back bumper, and it is more than 80", then you violate the rule.
In the case if the end of the arm is just under 80" from the center of the rear bumper, and the arm extends straight forward from the center of the robot, it would voilate the rule when measured from the ends of the bumper.
Make a sketch....post it...we're very good at arguing about stuff we can see.
Unread 14-01-2008, 14:49
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Definition of ANY is "one or more". Using Eric's definition, if your 'bot fits corner to corner diagonally, your good. Properly it would have to fit into the box in EVERY orientation.
Unread 14-01-2008, 15:01
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Originally Posted by jgannon View Post
Dave, read Eric's post again. He's saying that the bounding box is a square, but your robot must fit in it in ANY orientation. If you can fit such a square regardless of your orientation, then you are within <R16>. If there is some orientation such that you don't fit, then you are violating <R16>. As such, Eric's definition is precisely <R16>.
Nope, I still don't agree. Eric's definition is much too permissive. If the explanation had been "must fit in an 80-inch square in every orientation" then I might buy it. But not as written.
Yeah, that is exactly the point.
-dave
Unread 14-01-2008, 15:25
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Mea culpa. Your definition is unambiguous. Thank you, Dave.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 15-01-2008, 13:11
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I just wanted to point this out: the equilateral triangle isn't really the limiting case for a 3-sided figure. It's actually the curvilinear triangle with a width of 80 in. It has more area, for a given width.
Also, the triangle isn't the only figure for which this works: see here for an applet that demonstrates the principle for odd numbers of sides, from 3 to 21.
So, who's going to build a robot that fits a curvilinear pentagon, just to annoy the officials?
Unread 15-01-2008, 13:28
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
I guarantee someone will need something other than an equilateral triangle or a circle to fit (heck my team may even try it to make our programmers lives easier - last year we made them take an 86" jointed arm and contstrain it to 72" at all times through feedback on our sensors!!).
But what I want to know is is this going to be in the referee training... keep your Q&A and rulebooks on hand if you really want to nitpick this rule!!
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 15-01-2008, 13:37
Gdeaver Gdeaver is offline
FRC #1640
This is a bad rule. Even with a Q and A response it's still gray to teams. On the field with a fast moving wide open game this year , refs will have a difficult time enforcing the rule. I predict many teams will violate it and get away with it. There is still time for the rule to be modified so that teams can more easily comply and make the refee's job easier.
Unread 15-01-2008, 13:42
Remember the similar rule from last year? How do you determine whether a team is in the box? There were infractions last year that apparently weren't called, even on the diagonal part. This year at least means that the refs don't have to call on diagonals. They have one standard size. So some teams slide through. It's part of the game. I've seen soccer games where the ref saw a hand ball and didn't call it. As long as the rules are applied evenly to all teams at the event (and, ideally, all events), I don't really care.
Unread 15-01-2008, 13:54
AdamC's Avatar
AdamC AdamC is offline
Lathemeister
AKA: Batman
FRC #0395 (2Train Robotics)
AdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of light
Send a message via AIM to AdamC
Checking that article about curvilinear triangles (please don't harangue me for steering away from the original topic), does anybody know of a company that sells a curvilinear drill bit? It would be useful for drilling holes and then mounting a square locking pin as opposed to cutting notches and then mounting the pieces together (which changes the size of the bar stock). I suppose if they don't exist, I'll try and make one myself.
"The glass is neither half-full or half-empty. It is twice as large as it needs to be."
"Any job worth doing is a job worth dying for."
Unread 15-01-2008, 16:32
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
I think this is a GREAT rule. In the past the rule was that robots had to fit inside a certain box. There was all sorts of confusion about orientation of the robot inside the box, and how the box shifted, etc. It lead to lots of diagrams and complex measurements.
Now the rule is simple - if any two points on the robot, measured parallel to the ground, are more than 80" apart, the robot is too big.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 02-02-2008, 17:56
DPTeam270Driver's Avatar
DPTeam270Driver DPTeam270Driver is offline
Deer Park Driver
FRC #0270 (Falcon X)
Team Role: Driver
DPTeam270Driver will become famous soon enoughDPTeam270Driver will become famous soon enough
if the rule says a CYLINDER, then why is there talk of squares and triangles
we cant do anything by complaining. its just one of the thing that we have to design around. its part of engineering.
but.......
the way my team figured it out was that if the up right arm is 5 ft, and another arm(52 in) to extend out and reach up w/ claws ( at least 20 in it grab ball) to clear the front of the bot and bumpers, it will extend past the 80 in. theres almost no way that any bot would be able to pick the ball up and put it on the rack.
this was just my team, and we put it 2gether this morning, and found out it was 31 in too long when we had to grab the ball.
-team 270
Penalty re: <R16> GaryVoshol Rules/Strategy 4 10-01-2008 15:56
R16 Playing Configuration skimoose Rules/Strategy 11 07-01-2008 09:18
Senator Response re:FIRST & the state budget Brandon Martus Announcements 2 03-11-2007 16:45
New Bumper rule interpretation - straight from the lead inspector Gary Dillard Rules/Strategy 17 12-03-2007 14:56
Update 6 Q&A # 132 ... INTERPRETATION PLEASE!!!! archiver 2001 2 24-06-2002 00:26
