FIRST Back-up Battery Charger
Is the FIRST back-up battery charger made to be get power from the fuse panel or straight from the battery.
Re: FIRST Back-up Battery Charger
You should fuse EVERY power bus coming off the battery. The charge circuit is no exception. It will prevent an overall loss of power if something in that circuit shorts to ground.
To answer your question, technically, it'll work either way. But the smart answer is to determine the max current it will draw, and fuse it. |
<R50> pretty well covers it. The only thing connected straight from the battery is the 120A switch/breaker. You will fuse the charger, as it is a load. Any questions, see the 2008 power distribution diagram.
| On-Board Battery Charger | bronxbomber92 | Technical Discussion | 6 | 08-02-2007 11:11 |
| Battery Charger for long term battery care | DougHogg | Kit & Additional Hardware | 0 | 08-02-2003 15:25 |
| Battery Charger Circut | PyroPhin | Electrical | 1 | 30-01-2003 13:49 |
| battery charger | archiver | 2001 | 3 | 23-06-2002 23:20 |
| Battery Charger | jgrater | Kit & Additional Hardware | 1 | 12-04-2002 14:14 |
