Re: Q&A response - new interpretation of R16
Even though I planned for the previous interpretation, I kinda thought they might go this way. It can be verified/enforced with a tape measure rather than an 80 inch diameter fixture. I'm OK with it since the ruling was made early enough in the season (although a week ago would have saved alot of headaches.)
Maybe FIRST should construct giant 80" pairs of outside calipers. It would be entertaining to watch the Refs/RIs use them (I certainly want to use one). Then in the offseason, we can bronze them and make them into statues! I'm sure a giant caliper statue would fit right in at Dean's House. But seriously, I think this affords everyone a little more room to make their mechanisms work and clears up the rule early enough in the season. Good Job! *For those of you who were not around FIRST in 2002, see one of the many tape measure rule threads Last edited by The Lucas : 14-01-2008 at 14:55. Reason: added * |
http://www.chassisliner.com/Product_Measuring_All.shtml |
Yea! We get a couple more inches to work with, even if bumpers stay included (I talked earlier in ohter threads about not including the bumpers in the 80 inches). I for one am a happy camper.
Re: <R16> Interpretation -------------------------------------------------------------------------------- The rule states that the Robot may not have any two points more than 80 inches apart when measured horizontally. The parenthetical phrase is intended as a clarifying example, but it does not convey the same authority as the rule. It is recognized that a small set of configurations exist (with an equilateral triangle with 80 inch sides as the degenerate case) that are in compliance with the letter of the rule, but may violate the example. In all such cases the rule, and not the example, will be enforced EDIT: Wait a minute, no we don't, now I "R" confused. In my head I saw a small window expanding in front of the robot, that is until I drew a picture. It all went away in a hurry. Two vertical poles, 80 inches apart, robot with bumpers on must past between the poles with any and all manipulators going through a full range of motion no matter what the orientation is. Can we please exclude the bumpers? I know, if we excluded the bumpers then I would still want 83 inches. My head is finally starting to hurt! Thanxs Dave! Last edited by ALIBI : 14-01-2008 at 15:27. |
The maximum 80-inch dimension interpretation is very different than the you must fit within an 80-inch diameter cylinder interpretation if you have manipulators that articulate or open up to grab the ball. See this PDF.
like MIT's Giant Slide Rule, but enough threadjacking for me. I just couldn't get the image of a team of Robot Inspectors wielding giant calipers out of my head. |
#7
| Penalty re: <R16> | GaryVoshol | Rules/Strategy | 4 | 10-01-2008 15:56 |
| R16 Playing Configuration | skimoose | Rules/Strategy | 11 | 07-01-2008 09:18 |
| Senator Response re:FIRST & the state budget | Brandon Martus | Announcements | 2 | 03-11-2007 16:45 |
| New Bumper rule interpretation - straight from the lead inspector | Gary Dillard | Rules/Strategy | 17 | 12-03-2007 14:56 |
| Update 6 Q&A # 132 ... INTERPRETATION PLEASE!!!! | archiver | 2001 | 2 | 24-06-2002 00:26 |
