Go to Post No one can improve your team's situation but your team. - Ryan Dognaux [more]
Unread 14-01-2008, 14:01
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Vacuum
Originally Posted by jgannon View Post
I'd venture that not only is that not clear, it's most likely wrong.
<R60> prohibits the use of electric solenoids, meaning electromagnetically controlled linear actuators. It notes that pneumatic solenoid valves, such as the ones found in the KoP, are legal. It makes no mention as to restrictions of their application... as such, you can use them in your pneumatics, you can use them as part of your end effector, you can use them as ballast, you can use them as non-functional decorations, and if you can make it work, you can most certainly use them to control a vacuum.
I will again point out that the rule quite clearly states that vacuum is not considered pnuematics. Therefore you would be using the solenoid for a purpose other than pnuematic. I think this is quite clear.
Also you want to use vacuum solenoids not pnuematic.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 14-01-2008, 14:13
roboengr roboengr is offline
roboengr is an unknown quantity at this point
Re: Vacuum
The next thing on the valves is the pilot control of a valve. valves require a air pressure to work. Just keep that in mind. Dont use a venturi! It is not enough use a bima cylinder on a fisher price motor. the rest you will have to figure out.
Has anyone tried to use a vacume on the nylon cover? Tell the success or failure, please. I am not sure how much leakage there must be to over come in volume.
Unread 14-01-2008, 14:44
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Vacuum
Peter, <R60> only talks about what parts are allowed to be on the robot. It says nothing about how they are allowed to be used. Whether the solenoids we are allowed to use will physically work for this application is up for debate, but please don't spread misinformation when the rules say something else.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 14-01-2008, 15:04
Re: Vacuum
I am not spreading mis-information. We clearly disagree on the interpretation of the way this is written and both feel strongly that the way it is written agrees with our case. As such anyone who wants do this should directly ask about it through the FIRST Q&A system.
Thank-you 294 & 67
Unread 14-01-2008, 16:02
Re: Vacuum
As it turns out, you are.
The rule you are quoting, <R60>, is forbidding electric solenoid actuators. It's not saying anything about legal or illegal ways to use pneumatic solenoid valves. Ironically, the parenthetical comment that is intended to clarify the meaning is apparently what's leading you to misinterpret it.
Do you know what electric solenoid actuators are? They're the sort of thing that you find in chime doorbells, where an electric current causes a magnetic field to move a metal rod.
Unread 10-02-2008, 20:29
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Vacuum
Originally Posted by Ziaholic View Post
No comment on the legality of it ... but technically it'd be a challenge to convince me that it's worth the effort. We tossed that idea around for a little while during our brainstorming sessions, but it died off somewhat quickly.
For ball handling, with it's somewhat porous cover, the volume of air that you'd have to move would be huuuuge ... and the area of the suction cup would have to be pretty large. I don't think that a tank behind a solenoid would do the trick. I'd wager that you'd have to be constantly sucking large volumes of air to maintain a partial vacuum at the cup
Worth the effort? Challenge?
OK, some basic physics here. The ball is 40 inches in diameter. it is a sphere. So, you contact that sphere with a large circular hole (a box with a hole maybe?) behind which you have a vacuum source. Yes there will be leakage, so a centrifugal fan is in order (maybe a vacuum cleaner with the AC motor replaced with KOP motors?) If your circle is, say around 20" in diameter, that will give you an area of more than 300 square inches. With a delta P of 1 PSI, (Delta P is the difference in pressure, so 1 PSI of vacuum) that will give you 300 LB.s of holding force. Even a modest shop vac can create almost 2 PSI of vacuum, and a huge flow rate (relatively speaking) so any leakage around the rim is not even noticeable.
Not only is it doable, and worth the effort, look for it at a regional near you!!!
Unread 10-02-2008, 23:59
dtengineering's Avatar
AKA: Jason Brett
Re: Vacuum
While this is slightly different from storing a vaccuum in a tank before a match, it certainly ends any debate on whether a vacuum gripper will work.
http://www.chiefdelphi.com/forums/sh...ad.php?t=63732
Jason
Vacuum Valve Andrew Blair Pneumatics 14 12-03-2007 19:49
Vacuum tube. Eric Scheuing Kit & Additional Hardware 11 13-01-2007 14:04
Vacuum Generator Peter Matteson Technical Discussion 0 04-02-2005 15:58
Vacuum NoRemorse Rules/Strategy 25 22-01-2004 12:34
Vacuum nwagers Pneumatics 16 31-10-2003 15:57
