Go to Post According to that logic, Engineers would say there will be twice as many spectators as needed, and we all know that's not the case! - Taylor [more]
Unread 14-01-2008, 14:18
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Q&A response - new interpretation of R16
Yes! No cylinder! (They have effectively declared a square, but your robot must fit in it in any orientation.)
No they didn't. Read the Q&A answer again.
The rule is exactly the same as it was when it was written. An 80-inch square would have a diagonal measurement of 113.14 inches, which is a clear violation of the rule.
-dave
Unread 14-01-2008, 14:38
AdamHeard's Avatar
Lead Mentor
-dave
Out of curiosity; who's maniacal idea was it to have the 80" rule?
Unread 14-01-2008, 14:39
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Dave, read Eric's post again. He's saying that the bounding box is a square, but your robot must fit in it in ANY orientation. If you can fit such a square regardless of your orientation, then you are within <R16>. If there is some orientation such that you don't fit, then you are violating <R16>. As such, Eric's definition is precisely <R16>.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 14-01-2008, 14:42
Lavapicker's Avatar
Lavapicker Lavapicker is offline
FRC #1056 (Hot Rocks)
Lavapicker is just really niceLavapicker is just really niceLavapicker is just really niceLavapicker is just really nice
I'm still confused....does that mean we can have an arm that reaches out to 80 inches, as measured from the back of the bumber, and still be ok? That's the way I read it and then I see the Cylinder thing which contradicts it. Is there a definitive answer?
Unread 14-01-2008, 14:46
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
There is a definitive answer, but it's a bit hard to understand, apparently
If your measure from the end of your robot arm to either end of the back bumper, and it is more than 80", then you violate the rule.
In the case if the end of the arm is just under 80" from the center of the rear bumper, and the arm extends straight forward from the center of the robot, it would voilate the rule when measured from the ends of the bumper.
Make a sketch....post it...we're very good at arguing about stuff we can see.
Unread 14-01-2008, 14:49
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Definition of ANY is "one or more". Using Eric's definition, if your 'bot fits corner to corner diagonally, your good. Properly it would have to fit into the box in EVERY orientation.
Unread 14-01-2008, 15:01
dlavery's Avatar
Curmudgeon
Nope, I still don't agree. Eric's definition is much too permissive. If the explanation had been "must fit in an 80-inch square in every orientation" then I might buy it. But not as written.
Yeah, that is exactly the point.
-dave
Unread 14-01-2008, 15:25
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Mea culpa. Your definition is unambiguous. Thank you, Dave.
_
Unread 15-01-2008, 13:11
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I just wanted to point this out: the equilateral triangle isn't really the limiting case for a 3-sided figure. It's actually the curvilinear triangle with a width of 80 in. It has more area, for a given width.
Also, the triangle isn't the only figure for which this works: see here for an applet that demonstrates the principle for odd numbers of sides, from 3 to 21.
So, who's going to build a robot that fits a curvilinear pentagon, just to annoy the officials?
Unread 15-01-2008, 13:28
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
I guarantee someone will need something other than an equilateral triangle or a circle to fit (heck my team may even try it to make our programmers lives easier - last year we made them take an 86" jointed arm and contstrain it to 72" at all times through feedback on our sensors!!).
But what I want to know is is this going to be in the referee training... keep your Q&A and rulebooks on hand if you really want to nitpick this rule!!
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 15-01-2008, 13:37
Gdeaver Gdeaver is offline
FRC #1640
This is a bad rule. Even with a Q and A response it's still gray to teams. On the field with a fast moving wide open game this year , refs will have a difficult time enforcing the rule. I predict many teams will violate it and get away with it. There is still time for the rule to be modified so that teams can more easily comply and make the refee's job easier.
Unread 15-01-2008, 13:42
EricH EricH is online now
Remember the similar rule from last year? How do you determine whether a team is in the box? There were infractions last year that apparently weren't called, even on the diagonal part. This year at least means that the refs don't have to call on diagonals. They have one standard size. So some teams slide through. It's part of the game. I've seen soccer games where the ref saw a hand ball and didn't call it. As long as the rules are applied evenly to all teams at the event (and, ideally, all events), I don't really care.
Unread 15-01-2008, 13:54
AdamC's Avatar
AdamC AdamC is offline
Lathemeister
AKA: Batman
FRC #0395 (2Train Robotics)
AdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of light
Send a message via AIM to AdamC
Checking that article about curvilinear triangles (please don't harangue me for steering away from the original topic), does anybody know of a company that sells a curvilinear drill bit? It would be useful for drilling holes and then mounting a square locking pin as opposed to cutting notches and then mounting the pieces together (which changes the size of the bar stock). I suppose if they don't exist, I'll try and make one myself.
"The glass is neither half-full or half-empty. It is twice as large as it needs to be."
"Any job worth doing is a job worth dying for."
Unread 15-01-2008, 14:00
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
I don't totally understand the geometry behind it, but the second sentence in the linked article was "No - you can't drill square holes", so I'm guessing there's some reason that doesn't work.
_
Unread 15-01-2008, 14:05
MrForbes's Avatar
AKA: Jim
look at what happens when you start drilling a hole in a piece of metal, with a relatively large drill bit, like 1/2", using a handheld drill. Often the hole will start out with 3 curved sides, even though the bit has only two cutting sides. I think this is sort of what you're thinking of?
so try a 3 sided bit to make a square hole.
Penalty re: <R16> GaryVoshol Rules/Strategy 4 10-01-2008 15:56
R16 Playing Configuration skimoose Rules/Strategy 11 07-01-2008 09:18
Senator Response re:FIRST & the state budget Brandon Martus Announcements 2 03-11-2007 16:45
New Bumper rule interpretation - straight from the lead inspector Gary Dillard Rules/Strategy 17 12-03-2007 14:56
Update 6 Q&A # 132 ... INTERPRETATION PLEASE!!!! archiver 2001 2 24-06-2002 00:26
