Go to Post Just because its a robotics competition does not mean everybody is a big dork. - Taxi Quinn [more]
Unread 14-01-2008, 12:37
d25inferno d25inferno is offline
FRC #2554 (WarHawks)
d25inferno is on a distinguished road
Send a message via AIM to d25inferno
Programming IR sensor
how do you program the IR sensor to alter the way the robot moves in EasyC?
I dont see an IR sensor block! Can you make blocks?
Also one other question: Is it possible to convert the 2007 default code into blocks?
Thanks in advance.
Unread 14-01-2008, 14:28
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
Re: Programming IR sensor
I got this from someone else, but this is how you would use the IR board to tell the robot to do something.
if (GetDigitalInput(1)){
doWhatever();
else if (GetDigitalInput(2)){
doSomethingElse();
change the number in GetDigitalInput to whatever to fit your needs. Good Luck!
Unread 14-01-2008, 15:22
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Correct you use the digital input block.
The idea behind easyC is you don't need default code you can make your own default code with like 3 blocks.
I would recommend going through the "Getting Started" section of the help file buy the time you finish you should
be an easyC Jedi !
Do you have a VEX robot you can practice on?
Unread 16-01-2008, 13:05
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
We threw our IR board on our VEX and wrote a really, really dirty fast program.
Look at this for a sample.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 17-01-2008, 19:37
elvin23's Avatar
elvin23 elvin23 is offline
not cool
FRC #0354 (354)
elvin23 can only hope to improve
Send a message via AIM to elvin23
Talking Re: Programming IR sensor
i love IR sensers i made a simple program take a look i dont have pics but ill write one
BEGIN
autonomous
Variables
PrintToScreen("BEGIN\n");
SetPMW(1,0);
SetPMW(2,0);
PrintToScreen("END\n");
END
I never was a cool guy but i would like to be like the guy in the pic he's cool
Programming ultrasonic sensor in MPlab AdamHeard FIRST Tech Challenge 1 09-05-2006 00:40
Programming the parallax PING))) Ultrasonic Sensor edman Programming 3 18-02-2006 23:37
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
autonomous sensor programming ? Laura_d Programming 1 10-02-2003 17:46
Tips for Sensor Programming and Testing EricEnsor Programming 3 24-01-2003 11:28
