Go to Post But you are an influencer: Use it for good. - DonRotolo [more]
Unread 14-01-2008, 13:49
Generator of Entropy
FRC #2973 (The Mad Rockers)
Q&A response - new interpretation of R16
From Q&A answers:
The rule states that the Robot may not have any two points more than 80 inches apart when measured horizontally. The parenthetical phrase is intended as a clarifying example, but it does not convey the same authority as the rule. It is recognized that a small set of configurations exist (with an equilateral triangle with 80 inch sides as the degenerate case) that are in compliance with the letter of the rule, but may violate the example. In all such cases the rule, and not the example, will be enforced.
Unread 14-01-2008, 13:53
Re: Q&A response - new interpretation of R16
Originally Posted by Gary Dillard View Post
From Q&A answers:
Yes! No cylinder! (They have effectively declared a square, but your robot must fit in it in every orientation.)
(And Dave--if you read the edit--I did use the word "must" in the original.)
Unread 14-01-2008, 14:05
Even though I planned for the previous interpretation, I kinda thought they might go this way. It can be verified/enforced with a tape measure rather than an 80 inch diameter fixture. I'm OK with it since the ruling was made early enough in the season (although a week ago would have saved alot of headaches.)
Unread 14-01-2008, 14:18
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
Yes! No cylinder! (They have effectively declared a square, but your robot must fit in it in any orientation.)
No. They said, "the Robot may not have any two points more than 80 inches apart when measured horizontally." An 80" square will have a horizontal dimension greater than 80" (its diagonal).
Take the rule for what it says. No more, no less.
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
No they didn't. Read the Q&A answer again.
The rule is exactly the same as it was when it was written. An 80-inch square would have a diagonal measurement of 113.14 inches, which is a clear violation of the rule.
-dave
Unread 14-01-2008, 14:38
AdamHeard's Avatar
Lead Mentor
-dave
Out of curiosity; who's maniacal idea was it to have the 80" rule?
Unread 14-01-2008, 14:39
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Dave, read Eric's post again. He's saying that the bounding box is a square, but your robot must fit in it in ANY orientation. If you can fit such a square regardless of your orientation, then you are within <R16>. If there is some orientation such that you don't fit, then you are violating <R16>. As such, Eric's definition is precisely <R16>.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 14-01-2008, 14:42
Lavapicker's Avatar
Lavapicker Lavapicker is offline
FRC #1056 (Hot Rocks)
Lavapicker is just really niceLavapicker is just really niceLavapicker is just really niceLavapicker is just really nice
I'm still confused....does that mean we can have an arm that reaches out to 80 inches, as measured from the back of the bumber, and still be ok? That's the way I read it and then I see the Cylinder thing which contradicts it. Is there a definitive answer?
Unread 14-01-2008, 14:46
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
There is a definitive answer, but it's a bit hard to understand, apparently
If your measure from the end of your robot arm to either end of the back bumper, and it is more than 80", then you violate the rule.
In the case if the end of the arm is just under 80" from the center of the rear bumper, and the arm extends straight forward from the center of the robot, it would voilate the rule when measured from the ends of the bumper.
Make a sketch....post it...we're very good at arguing about stuff we can see.
Unread 14-01-2008, 14:47
The Lucas's Avatar
CaMOElot, it is a silly place
For reasons of irony and superstition, I would like to keep tape measures away from this rule*. Maybe FIRST should construct giant 80" pairs of outside calipers. It would be entertaining to watch the Refs/RIs use them (I certainly want to use one). Then in the offseason, we can bronze them and make them into statues! I'm sure a giant caliper statue would fit right in at Dean's House.
But seriously, I think this affords everyone a little more room to make their mechanisms work and clears up the rule early enough in the season. Good Job!
*For those of you who were not around FIRST in 2002, see one of the many tape measure rule threads
Robot Inspector
Unread 14-01-2008, 14:49
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Definition of ANY is "one or more". Using Eric's definition, if your 'bot fits corner to corner diagonally, your good. Properly it would have to fit into the box in EVERY orientation.
Unread 14-01-2008, 14:52
MrForbes's Avatar
AKA: Jim
It's called a "tram gage", and you can buy them
http://www.chassisliner.com/Product_Measuring_All.shtml
Unread 14-01-2008, 15:01
dlavery's Avatar
Curmudgeon
Nope, I still don't agree. Eric's definition is much too permissive. If the explanation had been "must fit in an 80-inch square in every orientation" then I might buy it. But not as written.
Yeah, that is exactly the point.
-dave
Unread 14-01-2008, 15:03
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Yea! We get a couple more inches to work with, even if bumpers stay included (I talked earlier in ohter threads about not including the bumpers in the 80 inches). I for one am a happy camper.
Re: <R16> Interpretation
EDIT: Wait a minute, no we don't, now I "R" confused. In my head I saw a small window expanding in front of the robot, that is until I drew a picture. It all went away in a hurry. Two vertical poles, 80 inches apart, robot with bumpers on must past between the poles with any and all manipulators going through a full range of motion no matter what the orientation is.
Can we please exclude the bumpers? I know, if we excluded the bumpers then I would still want 83 inches. My head is finally starting to hurt! Thanxs Dave!
Unread 14-01-2008, 15:22
JonA's Avatar
JonA JonA is offline
Embedded Firmware Engineer
no team (Semi-Retired)
JonA has a spectacular aura aboutJonA has a spectacular aura about
The maximum 80-inch dimension interpretation is very different than the you must fit within an 80-inch diameter cylinder interpretation if you have manipulators that articulate or open up to grab the ball. See this PDF.
"That mecanum guy"
- Woodie Flowers Finalist Award Winner: 2010 Minnesota North Star Regional
- Mentor and Founder of 7 FRC Teams since 2003.
- FRC Regional Competition Score Keeper/Field Power Controller, Robot Inspector, Control System Adviser, Judge
- Co-Founder, Alumni: Milwaukee FIRST Support Organization
- Board Member, Game Design Committee, Judge, MVP-FTA: Midwest Vex Programs
- Computer Engineering Alumni '06: MSOE
- Embedded Firmware Engineer: Rockwell Automation
Penalty re: <R16> GaryVoshol Rules/Strategy 4 10-01-2008 15:56
R16 Playing Configuration skimoose Rules/Strategy 11 07-01-2008 09:18
Senator Response re:FIRST & the state budget Brandon Martus Announcements 2 03-11-2007 16:45
New Bumper rule interpretation - straight from the lead inspector Gary Dillard Rules/Strategy 17 12-03-2007 14:56
Update 6 Q&A # 132 ... INTERPRETATION PLEASE!!!! archiver 2001 2 24-06-2002 00:26
