Go to Post My brain is borderline mush, I don't have much of a voice, and I don't think I could be much happier. - Billfred [more]
Unread 14-01-2008, 15:29
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
LED's on Relay Ports?
Does anyone know if it's against the rules to a LED directly off a relay port?
Unread 14-01-2008, 15:37
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Re: LED's on Relay Ports?
Can you be a little more clear??
I believe you are asking: Can you use the LED Relay pins on the Operator Interface that are built into the Joystick port to light LEDs.
The answer to that is yes. That is the most common way.
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 14-01-2008, 16:30
Kingofl337's Avatar
AKA: Adam
I'm sorry I meant on the RC, instead of connecting a spike
Unread 14-01-2008, 16:40
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
LEDs are not in the KoP, so they would be considered custom circuits. As such, they would be governed by all of the custom circuitry rules. The one you're probably most interested in is <R82>.
<R82> Inputs to custom circuits can be connected to the following sources:
* Branch circuit breaker outputs
* Speed controller or relay module outputs
* PWM, relay or digital outputs on Robot Controller
* Switches, potentiometers, accelerometers, sensors, and other additional permitted electronics.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 15-01-2008, 13:56
Kingofl337's Avatar
AKA: Adam
Excellent Smithers......
Unread 18-01-2008, 14:39
SteveJanesch SteveJanesch is offline
hopes he has enough oomph
FRC #1533 (Triple Strange)
SteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to behold
Leet,
You'll want to put a current-limiting resistor in series with the LED. There's only a limited total amount of current available at the RC ports, and tying the LED from output to ground will either draw enough current to burn out the LED or may draw enough current to cause a drop on the RC's internal voltage.
If you need more current than the RC can provide to get to your desired brightness, you _could_ use a Spike or another custom relay (or transistor) and a bigger current limiting resistor to run the LED off 12 Volts. Double check section 8 of the rules to see if what you have in mind is legal.
Steve
P.S. Let me guess - these are indicators to let the Robocoach know what command has been sent? Maybe color coded?
Attaching LED's to OI joystick ports? tpc Control System 6 15-02-2006 08:19
LED's gone wacky computhief263 Electrical 6 26-02-2004 19:19
LED's hedgehogger Electrical 1 21-02-2004 00:28
On the subject of LED's 1166 Electrical 2 31-01-2004 10:33
Team Color LED's Phil_Lutz Technical Discussion 4 18-01-2004 19:56
