Go to Post Unfortunately, there's no special type of transmission that will magically get you past defense. The best way to deal with defense is to practice, regardless of gearing. - connor.worley [more]
Unread 11-01-2008, 08:46
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
Roller chains generator
Hello everyone,
Does anybody knows a way to make the roller chains generator generates actual chainlinks instead of that blue belt arround the sprockets?
That would make nicer renderings
Last year I constrained every link and it was not cool
thanks.
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 14-01-2008, 12:17
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: Roller chains generator
Not that I know of.
Instead of placing and constraining all of the links I would place one pin link and one roller link and then pattern in the assembly. (There is a bit of a trick to get this to work.)
Attached is an example one of my students did (he got the catenary curve on the wrong side but otherwise nice).
Unread 14-01-2008, 12:44
Daniel_H's Avatar
This video is really good, but I can't think of a way to do that. In the previous years we used the chainer technique (create a surface in the chape of the chain's trajectory, contraint the links to it and then make the surface invisible).
I wonder how the pattern on the video was done.
[<o>] gogogo [<o>]
Unread 14-01-2008, 15:36
JD Mather's Avatar
It will be several weeks till we get to sprocket and chain drives. I will try to work up a tutorial by that time.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 14-01-2008, 19:30
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Try this:
http://www.team228.org/documents/Rol...n_Inventor.zip
I still do not know where this file came from, as I found it on one of the team's computers several years ago. All I know is that it works really well for generating roller chain assemblies in Inventor.
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-01-2008, 19:50
run the trap!!!
Team Role: Human Player
Originally Posted by artdutra04 View Post
Try this:
That came from the cbliss website. I could never get it to work. How exactly do you use it?
-Philip J. Fry
#25 & #35 chains JohnMorenski Technical Discussion 16 11-01-2007 19:24
VEX Chains chewy VEX 13 21-11-2006 14:14
chains sburro Technical Discussion 13 07-10-2004 11:37
chains in 3ds tinsLee123 3D Animation and Competition 4 17-02-2003 00:14
chains enjoiwheels Inventor 0 08-02-2003 19:33
