Go to Post Based on my experience coaching basketball and robotics, there is no doubt in my mind that if a sports coach receives $x then a robotics coach should, too. - dtengineering [more]
Unread 14-01-2008, 14:58
jleung jleung is offline
FRC #2605
jleung is an unknown quantity at this point
Is Kevlar Honeycomb allowed?
Our team has access to Kevlar Honeycomb, a lightweight board material, and we would like to know if its legal in competition.
Unread 14-01-2008, 15:06
Bob Steele's Avatar
AKA: Bob Steele
Re: Is Kevlar Honeycomb allowed?
Hey Bellingham!!
Sure its allowed!! It is a great material...
Most materials are allowed for competition. The costs must be figured out carefully though.
For instance. You must figure out what the smallest piece of honeycomb that could be purchased....if it is sold only in 4X8 sheets you will have to add in the entire cost of the sheet to your bill of materials for your robot.
This costing is kind of difficult the first time you do it but if you read the rules carefully it tells you how to do this.
Remember, even if the material is donated, you must include it in the bill of materials for your robot and you may not exceed $3500 for the robot.
If you have any questions about this let me know...
good luck
We look forward to working with you guys in the Seattle (Tacoma) regional
If you want to come down some weekend and try out your robot please let us know we would love to have you down!!
R
Unread 14-01-2008, 15:10
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
also if that 4x8 sheet costs more than $400 then you probably cannot use the material.
Read the rules carefully!
Unread 14-01-2008, 15:39
...Including the ones about all teams being able to obtain the material.
From the definition of VENDOR in Section 8:
VENDOR – A legitimate business source for COTS items that, as a minimum, satisfies the following criteria:
[snip]
• The VENDOR makes their products available to all FIRST Robotics Competition teams.
• VENDORS must not limit supply or make a product available to just a limited number of FIRST Robotics Competition teams.
And <R35>:
<R35> COTS ITEMS that are generally available may be used on the ROBOT. The parts shall be generally available from suppliers such that any other FIRST team, if it so desires, may also obtain them at the same price. A specific device fabricated by a team from non-2008 Kit Of Parts materials for their use does not have to be available to others; however, the materials it is made from must be available to other teams.
Unread 14-01-2008, 16:07
REVving up for a new season
FRC #2848 (All-sparks)
This is not correct. According to rule 8.3.5.1
The cost of items purchased in bulk or large quantities may be prorated on the basis of the smallest commonly available unit that satisfies the need for the item.
o Example: A team purchases a 4' x 4' sheet of aluminum, but only uses a piece 10” x 10” on their ROBOT. The team identifies a source that sells aluminum sheet in 1’ x1’ pieces.
The team may cost their part on the basis of a 1’ x 1’ piece, even though they cut the piece from a larger bulk purchase. They do not have to account for the entire 4’ x 4’ bulk purchase item.
According to this as long as the amount which is used on the robot has a value less then 400 it is fine to use. I would even say a team would be hard pressed to find a 4x8 sheet of 3/8 aluminum less then $400.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 14-01-2008, 16:14
GaryVoshol's Avatar
Cogito ergo arbitro
If 4x8 is the smallest size the material is sold in, then the entire 4x8 cost must be included in the BoM. You can prorate only when you buy in bulk sizes but smaller sizes are available.
(since 2004)
Unread 14-01-2008, 16:17
That's not how the rule is worded. It doesn't say you account for cost by how much you used. It says you account for cost by the smallest amount commonly available. If you can't get material in smaller than 4x8 sheets, you have to account for the entire sheet in your cost.
Unread 14-01-2008, 16:48
JimWright949's Avatar
JimWright949 JimWright949 is offline
The Owen Day of Seattle
AKA: Jim Wright
FRC #4542 (Titanium Talons)
JimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to behold
Hmm, this discussion actually made me realize I’ve been miscounting a cost for 6 years!
Our local metal dealer sells remnants of sheets of aluminum, before now I’ve been just counting the cost I buy those remnants at. I did this because the shop will sell you any amount you want with a cut fee, however since we are a high school they have always waived the cut fee (We usually ask them to cut our 21 foot beams down to 7 foot beams to transport them).
So even though we are buying remnants of aluminum from their cut off shop, we should count the cost of cutting the remnant, even though the person who caused the remnant to be left over paid the cutting cost.
-Jim
Unread 14-01-2008, 17:53
Bob Steele's Avatar
AKA: Bob Steele
Jim,
I think you were ok all along.
If the company will do business with anyone, then your costs were just fine.
Anyone would have been able to come in and purchase those materials so they are available to you at that cost. If they would waive the cut price for everyone or for FIRST teams in general , then you would NOT have to add that in either.
It all comes down to being generally available.
Hope you guys are doing welll!!
Robert
Unread 14-01-2008, 19:29
Gdeaver Gdeaver is offline
FRC #1640
I am all in favor of FIRST teams using composit materials and construction techniques. We Will be laying up some parts again this year. We will also probable use some pultrustions. However, Some teams have used some of the more exotic composite materials. I contend that many of them are not commonly available to all teams and do not pass the costing guide lines. This was brought up earlier on a prepeg post and now the arimid honey comb. I would love to see a link to a web site or company listing that would sell these materials in small quantities and the pricing. Put some fiber in your robots diet but do it with in the guide lines
Unread 15-01-2008, 01:21
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
then there is ebay, where does that fit in. Everyone has an even chance at putting in a bid.
Unread 15-01-2008, 01:23
MrForbes's Avatar
AKA: Jim
Yes, everyone can bid, but only one team can buy each item. I consider ebay to be an acceptable source for COTS items that are also available from an acceptable vendor. I don't know what FIRST thinks of ebay.
Unread 15-01-2008, 02:11
Capt. Quirk Capt. Quirk is offline
AKA: Bill Mazzacane
FRC #1704 (Robotic Steelers)
Capt. Quirk will become famous soon enoughCapt. Quirk will become famous soon enough
How much do you need?
If I were able to sell small amounts Nomex honeycomb or Roahcell #71IG foam and other vacuum bagging supplies would that make it legal for the FRC teams that wish to buy it?
Bill
Unread 15-01-2008, 02:21
Bill
Do or can you meet the definition of a VENDOR as described in Section 8?
Unread 15-01-2008, 08:18
Ok first things first, the rules in section 8.3.5.1 is
purchase item.
So if and only if, the item is available in smaller quantity can you prorate and only based on the smaller quantity price. If you purchased the smallest quantity available then the entire price is listed on the BOM.
Be careful with exotic materials. If they require repairs at competition, and also require special handling during those repairs, you may not be able to make the repairs at competition. Such was the case with composite graphite fiber for ramps last year. If the repairs give off toxic fumes or dust then you cannot expose the public to these dangers and repairs will not be allowed. Even though the material may make it through the approval process using the flow chart at the back of Section 8, the special handling may not.
NEED: carbon fiber/kevlar/composite I-beam Gabe15 General Forum 2 10-01-2008 08:44
aluimium honeycomb panels Matt21q General Forum 1 03-02-2007 11:45
Sensor allowed? SilverStar Electrical 6 18-02-2004 18:13
Magnets allowed?¿? Speed1130 Technical Discussion 35 30-01-2004 20:11
odification allowed gail OCCRA 6 10-10-2002 04:27
