Go to Post of course, like anything, there is big difference between "can" and "should" - ratdude747 [more]
Unread 12-01-2008, 23:03
cjtenny cjtenny is offline
FRC #2349
cjtenny is an unknown quantity at this point
Send a message via AIM to cjtenny
AM Coolie-Dualies VS Alum. Omnis?
Any opinions on the AM coolie dualies against their plain aluminum omnis?
Unread 13-01-2008, 12:09
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: AM Coolie-Dualies VS Alum. Omnis?
I'm looking for similar advice. I used the coolie dualies last year with great success. The coolie dualies were designed after the Molded plastic wheels. Many of the teams I see using the molded plastic wheels use two of the molded plastic wheels offset so a roller is always coming in contact.
The coolie dualies replace the concept of two offset molded plastic wheel for half the weight and price.
I have not used the plastic molded wheels, so I am also interested in team's experiences with the molded plastic omnis as well as the Alum. Omni.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 13-01-2008, 12:20
REVving up for a new season
FRC #2848 (All-sparks)
I have used both the aluminum omnis and the plastic ones, I recommend the plastic ones over the coolie dualies or aluminum just because of bearings. The molded omnis hold 2 bearings in for full support while both of the other kind require you to put a bearing in the attached sprocket. Just for ease of use the molded ones save you the trouble of finding flanged R6 or R8 Bearings.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 14-01-2008, 09:19
lynca's Avatar
Andrew Lynch
Thanks for the heads up on the dual bearings for the plastic molded. The Aluminum wheels state they can handle one bearing but I would imagine that is too much stress on the bearing. Last year with the coolie dualies, we used pillow blocks and directly mounted the coolies to the shaft.
Unread 14-01-2008, 15:51
lynca's Avatar
Andrew Lynch
I found a picture from the 2006 FIRST Book, page 88, FRC#123
Unread 14-01-2008, 15:59
That was a common problem on the first rev of the wheels due to over tightening of the screws that held the sections together, which caused cracking of the plastic. Since then the plastic has been and the torque specs of the bolts was reduced. I didn't hear of anyone breaking them in the 2007 season.
As for the bearing issue, Each wheel needs to have 2 bearings to support it, otherwise your wheel becomes an cantilevered load on your axle creating a moment with the possibility to bend your shaft or the wheel in the worst case. And best case is that your wheel will wobble.
Unread 14-01-2008, 16:04
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
FRC #1902 (Exploding Bacon)
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
What about how bumpy the rides were in previous years with different designs? Have any teams attempted over 13 fps on the molder plastic and alumninum wheels or the coolie dualies?
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
Unread 15-01-2008, 10:19
lynca's Avatar
Andrew Lynch
I think the failures to the Plastic Omni were for one year only According to Andy Baker,
Originally Posted by Andy Baker View Post
Yes, that first year, I thought that it was a good idea to put a 10% fiberglass fill into the black polycarbonate. While that made the tensile strength higher, it was lower rated on the Izod impact rating. The fiberglass mad the material brittle, and when teams hit the side of the 1 point ramp in 2006, the wheels broke. The result of these breaks were improving these wheels and creating the aluminum omni wheels.
So... last year we had black polycarbonate with no fiberglass filler, and that resulted in zero complaints about breakages.
If I had to pick which omni wheel to use on a FRC robot, I would choose the 6" aluminum omni wheel, and use an Omni Spacer to make them a dualie omni wheel. That is a sweet setup. The polycarbonate wheels are nice, and can handle 2 bearings, but the aluminum wheels take up less space (they are thinner) and they are repairable. The only negative about the aluminum omni wheels is that they only have the ability to have 1 bearing mounted to them, that is unless you add on an extra hub.
Andy B.
From this Thread
http://www.chiefdelphi.com/forums/sh...t=plastic+omni
AndyMark Coolie Dualie now available Billfred General Forum 7 27-12-2006 23:10
AndyMark aluminum omnis now online, plus a surprise Billfred General Forum 18 17-12-2006 19:10
[OCCRA]: Question? Extruded Alum Mike Martus OCCRA Q&A 0 16-09-2006 22:46
pic: The alum girls and I Pat McCarthy Extra Discussion 2 04-04-2006 22:49
Legal Alum. Mike Martus Off-Season Events 0 08-11-2001 19:37
