#16
Re: Vacuum
Also you want to use vacuum solenoids not pnuematic. |
#17
Re: Vacuum
The next thing on the valves is the pilot control of a valve. valves require a air pressure to work. Just keep that in mind. Dont use a venturi! It is not enough use a bima cylinder on a fisher price motor. the rest you will have to figure out.
Has anyone tried to use a vacume on the nylon cover? Tell the success or failure, please. I am not sure how much leakage there must be to over come in volume. |
#18
Re: Vacuum
Peter, <R60> only talks about what parts are allowed to be on the robot. It says nothing about how they are allowed to be used. Whether the solenoids we are allowed to use will physically work for this application is up for debate, but please don't spread misinformation when the rules say something else.
#19
Re: Vacuum
Re: Vacuum
As it turns out, you are.
The rule you are quoting, <R60>, is forbidding electric solenoid actuators. It's not saying anything about legal or illegal ways to use pneumatic solenoid valves. Ironically, the parenthetical comment that is intended to clarify the meaning is apparently what's leading you to misinterpret it. Do you know what electric solenoid actuators are? They're the sort of thing that you find in chime doorbells, where an electric current causes a magnetic field to move a metal rod. |
#21
Re: Vacuum
OK, some basic physics here. The ball is 40 inches in diameter. it is a sphere. So, you contact that sphere with a large circular hole (a box with a hole maybe?) behind which you have a vacuum source. Yes there will be leakage, so a centrifugal fan is in order (maybe a vacuum cleaner with the AC motor replaced with KOP motors?) If your circle is, say around 20" in diameter, that will give you an area of more than 300 square inches. With a delta P of 1 PSI, (Delta P is the difference in pressure, so 1 PSI of vacuum) that will give you 300 LB.s of holding force. Even a modest shop vac can create almost 2 PSI of vacuum, and a huge flow rate (relatively speaking) so any leakage around the rim is not even noticeable. Not only is it doable, and worth the effort, look for it at a regional near you!!! ![]() |
#22
Re: Vacuum
While this is slightly different from storing a vaccuum in a tank before a match, it certainly ends any debate on whether a vacuum gripper will work.
http://www.chiefdelphi.com/forums/sh...ad.php?t=63732 Jason |
| Vacuum Valve | Andrew Blair | Pneumatics | 14 | 12-03-2007 19:49 |
| Vacuum tube. | Eric Scheuing | Kit & Additional Hardware | 11 | 13-01-2007 14:04 |
| Vacuum Generator | Peter Matteson | Technical Discussion | 0 | 04-02-2005 15:58 |
| Vacuum | NoRemorse | Rules/Strategy | 25 | 22-01-2004 12:34 |
| Vacuum | nwagers | Pneumatics | 16 | 31-10-2003 15:57 |
