Go to Post If you base a team on how well you do on the field you have a much harder time winning. - Bob Steele [more]
Unread 11-01-2008, 20:14
Lucas's Avatar
Lucas Lucas is offline
FRC #1382
Lucas will become famous soon enoughLucas will become famous soon enough
Re: Team Update #2
On my think, the challenge become bigger! I was afraid to hold a trackball of 40"! So now I'm desperate!!!!rsrs
As higher the task, it will be better!
Good luck to everybody!
Go Teams!
Lucas Rafael from Team 1382 / Brazil
Unread 11-01-2008, 22:28
Optimizer Optimizer is offline
AKA: Frank Stanley
FRC #1507 (Warlocks)
Optimizer is a jewel in the roughOptimizer is a jewel in the roughOptimizer is a jewel in the roughOptimizer is a jewel in the rough
Re: Team Update #2
OK, so it's likely "102 cm", and not "120 cm". But am I remembering wrong, or wasn't it supposed to weigh 10 pounds? 2500g = 2.5kg = 5.5 pounds. Is the cover 4.5 pounds?
Unread 11-01-2008, 22:32
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: Team Update #2
Be sure to add the weight of air. It seems negligible, but at that size the air could weigh about a pound.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 11-01-2008, 22:40
AKA: Frank Stanley
Re: Team Update #2
I hadn't thought of that, but I don't think it applies. Archimedes principle, ya' know. Helium would actually subtract weight, for example. We're talking weight, not mass.
Unread 12-01-2008, 00:17
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Team Update #2
I must say I'm very dissapointed in the change to <G40>. Before an effective hybrid mode defense could be played by spacing robots out on the field so as to make it more difficult for opposing robots to navigatge, but opposing robots had a chance of getting through with some really clever programming (or good luck). Now any alliance can effectively limit their opponent to 32 points (3 robots crossing 2 lines and one knocked ball) by simply having all 3 drive forward for a second or two, with the defense only failing if one has enough pushing power to shove a robot a good 10 feet (not likely with many of this year's drivetrains geared for speed).
I wouldn't expect a good hybrid lap bot to get more than 8 points now, I was really looking forward to seeing at least one team pull off well beyond a full lap.
<G36> is a good add though, no sense in making an already disheartened team feel worse with the penalties.
Unread 12-01-2008, 00:49
dtengineering's Avatar
AKA: Jason Brett
Re: Team Update #2
Originally Posted by Donut View Post
Now any alliance can effectively limit their opponent to 32 points (3 robots crossing 2 lines and one knocked ball) by simply having all 3 drive forward for a second or two....
So that would be a 32-0 start for the non-defensive alliance? I think most alliances would be delighted to come out of hybrid mode with a 32 point lead.
I wouldn't worry too much about this rule change affecting the spirit of the game.... all it is doing is simply pointing out that a "bump to pass" rule in hybrid would be very awkward given the challenges that many, many teams have with auto code.
Jason
Unread 12-01-2008, 13:25
BlondeNerd's Avatar
BlondeNerd BlondeNerd is offline
AKA: Kate
FRC #0619 (Charlottesville Albermarle Robotics)
BlondeNerd is a splendid one to beholdBlondeNerd is a splendid one to beholdBlondeNerd is a splendid one to beholdBlondeNerd is a splendid one to beholdBlondeNerd is a splendid one to beholdBlondeNerd is a splendid one to beholdBlondeNerd is a splendid one to beholdBlondeNerd is a splendid one to behold
Re: Team Update #2
Remember, it says the bladder is 120 cm. The cover prevents the ball from extending more than 40 in. My panicked team ran out to check how big our ball really was this morning and realized this to be the case.
Why, yes, girls CAN build robots!
Unread 14-01-2008, 16:12
Ian S. Ian S. is offline
FRC #1522 (D.O.T.M Robotics)
Ian S. is an unknown quantity at this point
Send a message via AIM to Ian S. Send a message via Yahoo to Ian S.
Re: Team Update #2
So are the trackballs going to be 40" or 48" at the competition? My team is on the edge of a herder because of this new information..
D.O.T.M - Defenders of the Multiverse
2006 VCU Regional Finalists (thanks to team 345 & 384)
2008 VCU Regional Champions (thanks to team 345 & 1086)
Unread 14-01-2008, 16:15
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: Team Update #2
They are still 40" The bladders may be able to inflate to 48", but the protecting covering is still only 40"
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 14-01-2008, 16:21
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Re: Team Update #2
You have to add the weight of air, And make sure you weigh ur ball if at all possible, because the balls do not all weigh the same
Min-Max to the Max!
Unread 14-01-2008, 16:53
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Re: Team Update #2
That isn't how much the ball/bladder weighs, it is the weight of the PVC per cubic unit I believe. It's like the insulation in winter gear, 1000 gram thinsulate does not mean there are 1000 grams of thinsulate insulation in it. It is just the weight per cubic unit.
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 01-02-2008, 12:56
Frank Neuperger Frank Neuperger is offline
FRC #0842
Frank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to behold
Re: Team Update #2
Sportogo says they were the vendor to FIRST for the trackball cover but not the ball.
THe FIRST balls weigh 7.1 to 7.2 lbs. We did this measurement on a really good load cell.
The FIRST cover weighs ~1.5 lbs (weighed by Sportogo on spring scale with 1/10 lb graduations). This would suggest that the FIRST bladder should weigh 5.6 - 5.7 lbs.
The $20.50 Sportogo ball SP01501 weighs 4.4 Lbs (per Portogo) and does not have the "anti burst addative" that makes the PVS have the closed cell foam texture.
The $30 Sportogo Ball SP100001 weighs 4.8 lbs and does have the antiburst addative.
Both of the above bladders at almost 1 lb underweight. We are still on the hunt for the EXACT FIRST bladder.
Note that we did repair the 1.5 inch laceration in our ball by using PVC cement (the stuff for PVC pipes) and a patch made from a deflated 8" PVC ball of similar material (no foam) and clamping overnight. It seems to be holding air. We repaired the tear in the cover using an iron on patch before inflating the patched bladder. Be carefull with the temperature of the iron!
Team Update 16 (3/16) Joe Ross General Forum 2 17-03-2005 16:34
Team Update #9 Curtis Williams General Forum 10 03-02-2003 20:37
Team Update #7 Up Steven Carmain General Forum 5 27-01-2003 23:15
Team Update #3 is up pavelthegeek Rules/Strategy 8 24-01-2002 14:51
