Go to Post It goes to show how a FIRST team is not one person but a complex codependence of people who are all striving to meet the same goal. - Bill_Hancoc [more]
Unread 14-01-2008, 18:05
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
Re: Programming the Infrared board
Hi Brad -
Thanks for doing this. This is also a good example of showing that you can use the IFI headers in a WPILib program, something that's not so apparent on first glance.
Some questions:
- I think I understand what RegisterRepeatingTimer() does, although it is not really documented. The header file says that timer interrupt handlers are "called with interrupts disabled". However, do you not also need to disable interrupts when you access the shared globals in the main( ) routine?
- The variables "changed" and "previous" in your ISR don't seem to do anything? Again, I think I understand what you are trying to do (e.g. collect all the commands in between times that the program actually checks for them), but "previous" never gets set to anything other than zero, and "changed" is calculated, but then not used. Would it not be simpler to just say:
 irCommands |= current;
and then the main() routine can turn off each bit as it gets processed? I think that's what the code is essentially doing now, since "previous" is always zero.
pic: Programming prototyping board Andrew Schuetze Extra Discussion 3 08-12-2007 18:30
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
What is the true field infrared emitter? scottm87 Programming 4 20-04-2004 18:22
Ordering the TSOP34840 Infrared Receivers yaman Electrical 5 23-01-2004 02:10
Infrared Beacon Board AlphaOmega870 Electrical 5 23-01-2004 01:58
