Go to Post While Grace will carry you through good times and victory, Professionalism will carry you through hard times and defeat. - Venkatesh [more]
Unread 10-01-2008, 18:27
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Question Need help installing inventor
ok here we go.. i got to the autodesk site downloaded the 32bit version of Inventor. got it all extracted and im about to install it then..BAM
Operation completed sucessfully
failed to copy following files: SetupRes
then..
Setup initialization failed
thats it..but here the catch
im running MS Vista 32bit home premium
is this the problem?
or did i do something wrong?
ive installed inventor before but its always been on a xp machine and i never had and problems. Any Ideas?
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 10-01-2008, 18:29
The_Laughing_ManMII's Avatar
The_Laughing_ManMII The_Laughing_ManMII is offline
FRC #1361 (The Nightmares)
Team Role: Driver
The_Laughing_ManMII will become famous soon enoughThe_Laughing_ManMII will become famous soon enough
Re: Need help installing inventor
i haven't had any luck running our old programs on vista either... i feel your pain!
The question is not how far you must go, but how far you will be willing to go to achieve that what is needed. - Father from the Boondock Saints
Unread 10-01-2008, 21:57
jimmythetulip22's Avatar
jimmythetulip22 jimmythetulip22 is offline
AutoCad God
FRC #2189 (The Wolf Pack)
Team Role: Animator
jimmythetulip22 will become famous soon enough
I got my version of inventor to run just fine, and I have vista ulitmate.
What I maybe did different is not install anything else besides inventor, try that and it might work!
Good luck, and i feel your pain also...
Life is like a roller coaster.
Sometimes you go up,
Sometimes you go down,
Sometimes, you fall off and die!
Unread 13-01-2008, 20:02
Loubear's Avatar
Loubear Loubear is offline
AKA: YLou
FRC #0075 (RoboRaiders)
Loubear will become famous soon enoughLoubear will become famous soon enough
You used the student downloader didn't you? The problem that I had with vista while downloading was that it didn't download everything... Use the zipped installation files instead.
Unread 13-01-2008, 20:06
aksimhal's Avatar
aksimhal aksimhal is offline
AKA: Anish
FRC #1123 (Autodidactic Intelligent Minors)
aksimhal is an unknown quantity at this point
Send a message via AIM to aksimhal
...Or you can also use the FirstBase downloader tool. Might help.
Unread 14-01-2008, 08:02
Marksman MD Marksman MD is offline
Inventor Master
AKA: Mike
FRC #1591 (Greece Gladiators)
Marksman MD is an unknown quantity at this point
Send a message via AIM to Marksman MD
yeah, I'm having the same problem with windows vista, you can download a fix from autodesk but you need to have the program already installed to use it which makes no sense.
Any help would be appreciated.
Unread 14-01-2008, 16:54
aksimhal's Avatar
AKA: Anish
I don't have vista, but a team member does and his works fine (although he did use the students.autodesk.com site for the free download). Is it possible to install the downloader tool in Vista?
Unread 14-01-2008, 17:26
Inventor Master
AKA: Mike
yeah, I have the student download program on vista, i have downloaded autodesk inventor but when the program goes to install, it says that the operating system is not supported.
"Inventor hates us all"
Unread 14-01-2008, 18:18
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I have just installed Inventor 2008 on both my Vista Ultimate x64 and my Vista Ultimate x86 boxes without any real issues.
On the x64 box I had to run setup32.exe directly since there is no setup64.exe, and the first time my download got courrupted(wouldn't de-compress), but both machines installed and ran fine. I did use the download tool.
I would try re-downloading.
Eric Haskins KC9JVH
need help assembling parts in inventor .. (was: help) jhallel Inventor 5 22-02-2007 01:46
Inventor (need help starting) rohit Inventor 12 15-01-2007 19:33
Installing inventor in personal computer Daniel_H Inventor 9 20-01-2006 23:47
I need help in inventor Nick R. Inventor 4 14-10-2003 08:04
Problems Installing Inventor Adam Shapiro Inventor 8 17-01-2003 22:45
