Go to Post I just want to see Aerial Assist again. Played on Lunacy regolith. With minibot poles. Which are on coopertition bridges. Is that too much to ask for? ;) - M. Lillis [more]
Unread 13-01-2008, 20:42
ebowla's Avatar
ebowla ebowla is offline
The Overmind
FRC #2016
ebowla is on a distinguished road
That darned clib.lib
After poring over numerous errors... NOT EVEN CODE ERRORS! I'm using default 2007 code trying to get it to compile, but I had a large number of problems. After fixing many of them, I have narrowed it down to 1. I get the stupid error that MPLAB couldnt find clib.lib. I have MPLAB 7.20 and C18 2.40. I did a search on my entire computer for all *.lib files. Only 12 hits thankfully, but I did not have the clib.lib anywhere.
Could someone direct me to where I can get this clib.lib? where to put it? Or anything that might fix my problem that I wasn't thinking of.
Thanks.
Progamming Master
Disclaimer: May not be actually as good as claimed, not reliable for advice, and shirks away any real work.
Unread 13-01-2008, 21:27
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: That darned clib.lib
I had that same problem about a month ago. It has to do with MPLab not recognizing the compiler. I was getting the message because I installed MPLab after the C18 compiler, and you really need to do it in the other order.
There might be a way to fix it by changing something in your build options or something, but I don't know what exactly, so I uninstalled the C18 compiler, and reinstall it, and it worked.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 13-01-2008, 21:31
baop858 baop858 is offline
FRC #0069 (Hyper)
baop858 will become famous soon enough
Send a message via AIM to baop858
By default it's C:\mcc18\lib if it isn't there, I would suggest reinstalling the c18 complier.
Unread 13-01-2008, 22:04
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
You usually get this error if your MPLAP project doesn't have the right library path set.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 13-01-2008, 22:11
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
You need to go to the project menu then build options then project
On the directory tab select Library Search Path, create a new one that points to the mcc18\lib folder where ever that may be, it might be in C:\Program Files\ or just under C:\
Unread 14-01-2008, 18:31
ebowla's Avatar
The Overmind
FRC #2016
I uninstalled it and reinstalled it and finally I have clib.lib. I checked before I uninstalled and I DID NOT have a lib folder in my mcc18 folder which was under C:\Program files\Microchip\mcc18\....and then nothing useful.
I dont know how it happened but fixed now.
Progamming Master
Unread 17-01-2008, 11:30
John Hooper John Hooper is offline
John Hooper can only hope to improve
You, my friend, have just saved me an enormous amount of time and aggravation! Works perfectly now. Thanks.
Unread 20-01-2008, 20:07
rpgcubed's Avatar
rpgcubed rpgcubed is offline
AKA: Nick
FRC #2456 (Recycle-It!)
rpgcubed is an unknown quantity at this point
Thank you so much! I wasted three hours working on this.
FIRST Inventor lib? Tottanka Inventor 17 26-09-2007 20:55
help with clib.lib nirvanapunk1015 Programming 1 10-02-2007 10:46
WHERE IS ifi_library.lib ?? LieAfterLie Programming 0 02-02-2007 17:53
That darned Rule DQ11 archiver 2000 5 23-06-2002 22:28
