Go to Post If only 5% of American entry level workers are proficient in algebra in 2022, I'm moving to Canada. - PVCpirate [more]
Unread 14-01-2008, 19:57
Mithiasis Mithiasis is offline
FRC #0074
Mithiasis is an unknown quantity at this point
Can you apply an assembly extrusion to a part?
Team 74 has made a full assembly of our frame and in this assembly we trimed a peice tube with the "cut" extrusion. This was done in the actual assembly not in the part its self.
So my question is this: Can we then apply this extrusion so that it shows up in our part's drawing?
Thanks
Can the VEX controller be programmed in assembly? Capt. Quirk Programming 7 23-12-2007 09:31
Assembly to Part Zoheb N Inventor 8 07-02-2007 01:26
Can we use part of a container on our robot? Rick General Forum 1 10-02-2003 20:10
Can I reduce the number of similar part files? roknjohn Inventor 2 29-01-2003 21:36
How much can the window assembly lift? archiver 2000 9 23-06-2002 22:59
