Go to Post Like a moth to a flame, true FIRSTers are attracted by the Victor instead of the Banner. - Rich Wong [more]
Unread 14-01-2008, 18:21
pyr0b0y pyr0b0y is offline
Programmer/Electrical
AKA: Josh
FRC #0253 (Mills Robotics Team)
pyr0b0y is an unknown quantity at this point
Send a message via AIM to pyr0b0y
3ds Max problems
i have made a geosphere and a tube and want to add an omni light and modify it. i have added the omni light and modified the basic parameters, but i need to add the "Atmosphere and Effects" one, specifically the lens effect. whenever i try and "Add," a window pops up and says an error occured, then the program closes. any help you could offer wood b helpful. thanks!!!
Unread 14-01-2008, 19:27
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: 3ds Max problems
first off what is the effect you are trying to achieve and why? What do you want your final product to look like? There are many ways to get the same effect. If this isn't working for you we can figure out another path to take.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 14-01-2008, 19:36
AKA: Josh
i trying to create an outerspace scene, i wanted to use lens effect, glow, string, streak, ray, and ring mostly. thanks!!
Unread 14-01-2008, 20:06
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
why dont you try a sphere with self-illumination turn all the way up and then put a fall off in the opacity map parameters. If you are trying for a sun-glowyish thingy.
Another way to do glows, is to render out a completely white sphere with self-illumination turn all the way up in the place where you want the glow. render the sphere out as separate layer and take that layer in to Combustion and then blur the layer, change the color of the layer and viola! a glowy layer without your computer spending time rendering the glow frame by frame.
A.K.A Llama
3ds max 7 installation problems sirbleedsalot 3D Animation and Competition 1 15-05-2005 21:18
3ds max 6 problems LBK Rules 3D Animation and Competition 3 15-01-2005 22:46
Problems with 3DS Max Licensing jlewellen 3D Animation and Competition 10 24-11-2004 14:58
3ds max 6 Bduggan04 3D Animation and Competition 20 03-09-2003 20:37
3ds max problems.. cgDynasty00 3D Animation and Competition 9 26-03-2003 07:36
