Go to Post I believe it is healthy to leave FIRST at some point and carry on with a well-rounded life (family, fun, school, & work). Focus your creative energy on developing your skills as a professional; then, come back to FIRST as a mentor later down the line. - Erin Rapacki [more]
View Poll Results: Is it bad to shutdown a computer by using the Power Button
Yes 24 55.81%
No 15 34.88%
Undecide 4 9.30%
Voters: 43. You may not vote on this poll
Unread 14-01-2008, 17:18
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Re: Computer Shutdown
I'm sure that it doesn't let your computer save your settings.
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 14-01-2008, 18:50
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I corrupted a drive once by holding the power button. Luckly I'm paranoid about loosign data so I had backups.
You should only do that as a last resort.
If you have it configured to shutdown properly, go into sleep, ect., thats fine, but killing it is bad.
EDIT: Someone menitioned USB drives getting corrupted, I had that happen once too, but that wasn't backed up.
Eric Haskins KC9JVH
Unread 14-01-2008, 20:19
Sam Fisher's Avatar
Sam Fisher Sam Fisher is offline
Master of Shop
AKA: Sam Perry
FRC #0145 (TRX)
Team Role: Student
Sam Fisher is an unknown quantity at this point
On my Latitude C600 under Power management it has a section asking what the computer should do when the power button is pressed, so i guess if they have a section for it it must be ok. I normaly don't turn it off that way and only use it when the system becomes frozen. But I don't seen any problem with forced shutdown occasionaly.
If you just don't want to wait for it to shut down change the registry(Found this on the web)
Sometimes when you're shutting down, XP will sort of just sit there and twiddle its thumbs, so to speak. That's because it is waiting for applications or services to stop hanging and shut down. Eventually it will do something about it, but why not get to it quicker? Here's how to make XP force a quick shutdown
1. Click Start -> Run -> type 'regedit' -> OK
2. Locate 'HKEY_CURRENT_USER\ Control Panel\Desktop\'
3.Select 'WaitToKillAppTimeout'
4. Right click and select 'Modify'
5. Change the value to '1000'
6. Now select 'HungAppTimeout'
7. Right click and select 'Modify'
8. Change the value to '1000'
9. Now find 'HKEY_USERS\ .DEFAULT\Control Panel\Desktop'
10. Select 'WaitToKillAppTimeout'
11. Right click and select 'Modify'
12. Change the value to '1000'
13. Now find 'HKEY_LOCAL_MACHINE\ System\CurrentControlSet\Control\'
14. Select 'WaitToKillServiceTimeout'
15. Right click and select 'Modify'
16. Change the value to '1000'
Check Out Instructables A great user generated site.
I'm a E-bay Junkie
Counter-Strike Noobie
FIRST Robotics Addict
Unread 19-01-2008, 15:01
PC-Dad's Avatar
PC-Dad PC-Dad is offline
CTRL+ALT+DEL
AKA: Mike Tarlton
FRC #1889 (H.A.Z.E.)
Team Role: Parent
PC-Dad is on a distinguished road
Send a message via AIM to PC-Dad
Wow, pretty good thread on such a simple thing as how to use the power button on a PC! The FIRST crew never ceases to amaze me.
To summarize, you all are pretty much in agreement that pressing and holding the power button to forcefully shutdown should be considered a last-resort measure. The typical type of problem associated with this action is data corruption or data loss, usually due to a disk write being in progress when the power is shutdown.
As for the ability to program the power button, I've always advised people to stay away from that and to use the GUI for shutdowns/hibernates/sleeps instead. The reason IT folks like me make broad statements like, "NEVER shutdown your PC that way" is because we usually don't know how much computer savvy the user in question has, so better to be safe than sorry. The bottom line is this: if you know the pitfalls, and you know the mechanics of what you are doing, then proceed at your own peril. If you're not sure what might happen, then you should stick to the safe route.
Michael Tarlton, MCDST, A+
Parent/Mentor
Team 1889 (Team HAZE)
Offline computer? Calvin Programming 2 19-01-2006 14:22
Computer Stupidity sanddrag Chit-Chat 1 10-07-2005 17:50
Startup/Shutdown sounds Jeff Rodriguez Chit-Chat 4 06-06-2004 22:42
My computer is nuts LBK Rules Chit-Chat 6 28-01-2003 19:43
Computer control maDGag Programming 1 27-12-2002 01:13
