Go to Post On day two of build season, I made the mistake of saying "We have six weeks, what could possibly go wrong?" - Zach Herbst [more]
Unread 10-01-2008, 16:05
diesel's Avatar
diesel diesel is offline
FRC #2077
diesel has a spectacular aura aboutdiesel has a spectacular aura about
Question Direct Drive from Toughbox Gearbox
Our team is looking to directly drive a wheel from the Toughbox Gearbox.
We would like to use an IFI traction wheel or a AndyMark performance wheels.
How would we go about doing this?
Any help would be nice.
Design. Build. Dew.
Unread 10-01-2008, 16:08
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: Direct Drive from Toughbox Gearbox
The 500 key hub from andymark will work for this.
http://andymark.biz/am-0077.html
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
My team is also interested in this concept so any ideas would be appreciated.
we might have a problem with our 8" wheels being too fast for this though...
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 10-01-2008, 16:10
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
You may want a longer shaft for the output shaft of the the tough box. Your wheels or the hub on the wheels need a key. I believe you can also lengthen the output shaft with a hex coupler to use with the performance wheel with the hext bore. If I remember one was actually in the 2004 kit.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 10-01-2008, 16:18
AJ R's Avatar
RoboGeek
We may need a longer shaft on our transmission too. I wonder if the long axle from the super shifter could work? Or will the hex part be too long inside of the transmission?
http://andymark.biz/am-0126.html
AJ
Unread 10-01-2008, 16:21
Imaginary Friend
AKA: Kevin Li
Team Role: Student
It looks long enough that the hex part will be outside of the gearbox. I'm assuming it's the right diameter?
Kevin Li
596 - Sciclones
Unread 10-01-2008, 16:37
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
I believe that it is the right diameter, however, the back end is too large and the hex part is too long so unless you have a lather and are willing to modify it you aren't going to be a ble to use the hex shaft from the supershifter.
Unread 14-01-2008, 22:05
Chipawa's Avatar
Chipawa Chipawa is offline
AKA: Mr. Tucker, AKA Chip
FRC #1111 (Powerhawks)
Chipawa is an unknown quantity at this point
This has become an issue for our team, too. We are considering driving an AndyMark omniwheel directly off of the toughbox and figure we are going to need a shaft coupling. Any advice would be appreciated.
~Chip Tucker
2010 DC Engineering Innovation Award
2010 DC Spirit Award
2008 Chesapeake Finalist
2008 Chesapeake Rockwell Automation Innovation in Controls award
Unread 14-01-2008, 22:44
Imaginary Friend
AKA: Kevin Li
Team Role: Student
You can try and look for shaft couplers on mcmaster.
Kevin Li
596 - Sciclones
Unread 15-01-2008, 13:38
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
Ah, I was wondering if anyone else was having this problem as well. I talked to AndyMark and they do not have a longer output shaft that will work with the ToughBox. Two ways to resolve this if you want an axle that goes all the way through:
1. connect the output shaft to an axle using a shaft coupling. There are several models available at Mcmaster and Grainger or other places like that. You can choose from a ridgid coupler or a flex coupler that would allow for some play or misalignment between the shafts (be careful with torque ratings on these).
2. the output shaft has a 1/4-20 tapped hole in the end (1/2" deep). We are using a Grade 8 1/4 - 20 bolt through our outer wheel plate (with a bearingin the plate) as our axle and it will screw directly into the output shaft. The bolt will have spacers over it to take up the remaining space within the wheel center bore. Then we use the keyed Shaft HUB that AM sells to actually drive the wheel from the output shaft.
We have not tested option 2 under load or anything but I belive it will be strong enough. Without this bolt, the wheel would essentially be supported by the toughbox which is also plenty strong in most cases I think.
Unread 16-01-2008, 04:06
sheikhmo sheikhmo is offline
FRC #2471
sheikhmo is an unknown quantity at this point
I'm a mentor for a rookie team, and nobody on our team has had any mechanical experience (I'm an electrical engineer). Our team is also looking at powering the center wheels with the Toughbox. We would like to avoid chains and just use a direct drive method.
So since I have no experience with mechanical stuff, I was wondering if anyone had a picture or drawing of how to do this. The manual has some drawings on how to mount a wheel and using chains, but nothing on direct drive. Also, just to give you an idea of how little I know, I don't know what a hub is!
Any help would be much appreciated.
Unread 16-01-2008, 04:30
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
If going trying to find a longer shaft for the toughbox, you must purchase the 2" extended shaft for the AndyMark single speed gearbox and then on input end, use a lathe to take the diameter down from 1/2" to 3/8". You may also need to consider a different bolt or drilling out a larger hole on the output side of the shaft.
The shaft is not hardened so your lathe should be able to do the job as well as any other steel part. Keep in mind, AndyMark does not sell a longer shaft, or endorse this style of shaft. Use this at your own risk and please do not send out emails to AndyMark complaining if you are having difficulty.
Hope this works.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Running Banebots Transmission in Direct Drive Marcel Motors 6 27-01-2007 22:20
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
Help! Direct Drive Issues roberthan Motors 16 21-09-2006 09:33
pic: 1097 Direct Drive 01 Anthony Kesich Robot Showcase 16 13-09-2005 22:33
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
