Go to Post Since you have to undo all the connections anyway in order to swap them, you might as well take advantage of the opportunity to do some simple and straightforward troubleshooting. - Alan Anderson [more]
Unread 14-01-2008, 22:24
Darren Collins Darren Collins is offline
Coach
AKA: Darren Collins
FRC #2046 (Bear Metal)
Darren Collins is a name known to allDarren Collins is a name known to allDarren Collins is a name known to allDarren Collins is a name known to allDarren Collins is a name known to allDarren Collins is a name known to all
Cable Versus Chain
Our team is considering a lifting manipulator, and I was wondering if anybody had a preference of driving with either cable or chain.
Question 1: Cable or chain? Why?
Question 2: Drive one cable/chain from the middle or two cables/chains from the sides?
Unread 14-01-2008, 22:29
EricH EricH is online now
Re: Cable Versus Chain
For a lift (like a forklift), I think most teams use cable. I believe that 330 often used one in the middle for a single-stage and then a two from the sides for additional stages. (Note: You should probably also plan to pull the lift down. A single cable attached to the same winch as the one to pull up should suffice.)
Cable/winch vs. chain for telescopic arm VEN Technical Discussion 9 20-01-2007 22:37
PC versus Console Denman Chit-Chat 40 22-05-2005 18:01
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
Reigonals versus startegies MisterX Rules/Strategy 11 29-03-2004 00:04
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
