Go to Post Hey people, I found out the answer to my question and that one guy eric is right all you have to do is read the manual. The rules are in chapter 7.3.5.1, sections - .:) - ronald [more]
Unread 14-01-2008, 22:37
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Re: Hybrid Challenge-No Robot Left Behind
Originally Posted by Travis Hoffman View Post
How about we post and refine a simple, drop-in dead reckoning autonomous here in this thread so rookies and others can integrate and practice tuning such code ahead of time?
Why put teams under more pressure AT the events when you can help bridge the gap now, while there's still ample time?
That sounds like a good idea Travis. However, some things to consider:
Teams use different framework codes - IFI's, Kevin Watson's, WPILib, EasyC. Each would need a different autonomous mode.
Teams use different pwm outputs for their drive motors, making it not truly a drop-in.
Teams use different gear ratios for the motors, so without encoders (or something similar, that regardless makes the whole routine a lot less drop-in-able) it would be hard to travel the same distances. While crossing the first line should be doable regardless, trying to add the turn would take more work.
Left behind??? A scary story... meaubry Championship Event 4 04-04-2007 21:32
Left or right handed robot? DjAlamose General Forum 13 06-02-2006 15:51
Robot veers left when driving backwards! xxmaddjxx Technical Discussion 3 19-02-2005 04:57
Pa robot challenge Dave_222 Off-Season Events 77 16-01-2004 22:18
PA Robot Challenge VI cbudrecki Off-Season Events 1 29-03-2003 22:19
