Go to Post We have a little saying on our team. "Don't worry, we'll fix it in software." - klrswift [more]
Unread 14-01-2008, 22:44
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Fisher Price Gearbox
Good posts, thank you all for the ideas.
2017 Scoring Model
CAD Library | GitHub
Unread 15-01-2008, 01:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
If you're in the business of manually making an octagon without precision tools, here's what I'd recommend: Draw it in CAD, mark the center in CAD, print it out 1:1, cut it out, use 3M spray adhesive on your material, stick your drawing to it, get a cuttin!
Unread 17-01-2008, 13:11
JesseK's Avatar
FRC #1885 (ILITE)
Quick question: I've found 2 sources of data for the gear ratio of this gearbox. One says it's 124:1, the other says it's 188:1.
Can anyone confirm?
2017 Scoring Model
Unread 17-01-2008, 16:41
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
For the teams that have driven arms with the FP through the gearbox, have you run into any issues with heat? Specifically when you are holding the arm at a set position (up in the air). I know the FPs are cooled by fan blades that spin when the motor spins, so it seems to me that heat may be a problem when the motor is exerting torque but not spinning.
Unread 17-01-2008, 22:47
Psychotechnoid's Avatar
Psychotechnoid Psychotechnoid is offline
Team President/Programmer
AKA: Ted Hilk
FRC #1810 (Psychotechnica)
Psychotechnoid has a spectacular aura aboutPsychotechnoid has a spectacular aura about
http://store.mendingshed.com/wheeldriver1.html
I'm not totally sure that this is the exact coupler used by these motors, but my team ordered two of them (they're only $4 a piece) to see if we can make the FP gearbox outputs a little more useful.
Cheers!
Quia potentia mens mentis
Unread 18-01-2008, 00:47
Bruce Newendorp Bruce Newendorp is offline
Engineer
FRC #0525 (Swartdogs)
Bruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to behold
We have used the plastic couplers several years and they work well. An easy way to connect the coupler to a keyed shaft is to buy a 4" V belt pulley and cut half of the pulley off leaving a 4" round flange with a nice keyed shaft coupler. Drill 4 matching holes in the pulley flange and the plastic coupling, add screws, drill out the plastic coupling to 1/2", put it all on a 1/2" keyed shaft and you have a connection that will not fail.
We will be doing this next week for this year's robot.
Unread 18-01-2008, 13:23
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Yes, heat can be a problem if you use FP motors to hold an arm in position. If your motors are operating close to stall when doing so, you can fry the motor in about 30 seconds. I had some problems with this last year. You can solve this in a couple of ways: use more gearing, or use 2 FP motors and gearboxes. Either one of these methods will reduce the workload of your motor, and make it less likely to heat up. You can also use a worm gear so your joint won't backdrive, though this requires building a custom gearbox, and not using the FP gearbox in the kit.
Jeff Waegelin
Unread 22-01-2008, 11:44
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Can anyone confirm?
We've got the same dilema, can anyone answer?
BTW, can we check those sources?
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 22-01-2008, 13:18
JesseK's Avatar
FRC #1885 (ILITE)
Source 1: JVN's Spreadsheet calculations -- some of the spec #'s are from previous years and do not apply to 2008, so that's the only reason I question it
Source 2: FIRSTWiki
2017 Scoring Model
Fisher Price Gearbox Model? AdamHeard Inventor 1 12-01-2007 05:56
Fisher Price Motor Replacement Gearbox Joe Johnson Motors 17 05-01-2007 07:35
Fisher-Price Gearbox? Aaron Motors 4 17-02-2004 17:41
Fisher Price gearbox Manoel Motors 0 14-02-2003 16:06
Fisher Price Gearbox Q... Anton Abaya Motors 17 27-01-2002 08:39
