Go to Post Go get Al, he probably isn't busy! - Jimmy Nichols [more]
Unread 14-01-2008, 22:52
Nothing551 Nothing551 is offline
FRC #0333
Nothing551 is an unknown quantity at this point
Possession of trackball
I know this might be a dumb question, but i am unsure of it.
Can we drive under the overpass, with the trackball in possession?
Unread 14-01-2008, 22:53
Re: Possession of trackball
Not if you want to score trackball points.
Originally Posted by Section 7
<G10> Each TRACKBALL that has CROSSED its own FINISH LINE while not in contact with a ROBOT of the same ALLIANCE will earn 2 points. A TRACKBALL that has CROSSED its own FINISH LINE which contacts ROBOTS of both ALLIANCES while CROSSING will earn 2 points.
(emphasis mine)
You will still get the robot points, but why settle for two points when you can have four?
Unread 14-01-2008, 22:57
FRC #0333
Wait I don't understand, how can you get 4 points?
Unread 14-01-2008, 22:59
technoL's Avatar
technoL technoL is offline
AKA: Noelle Manning
FRC #0108 (SigmaC@T)
technoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud of
Send a message via AIM to technoL
The robot crossing the finish line counts for 2 points, while the trackball crossing the finish line counts for two points separately. If you can do both -- driving the robot to the line, releasing the trackball across the line, and then driving the robot across the line, you'll score 4 points.
<G06> During the TELEOPERATED PERIOD, a ROBOT will earn 2 points each time it CROSSES
its FINISH LINE.
2 points.
Team Leader | Mechanical | Driver | SOAP | Anything
2008: NJ GM Industrial Design Award, 4th Seed | FL Rockwell Automation Innovation in Control Award, 1st Seed, Semifinalists
2007: FL Finalists | LV Xerox Creativity Award, Quarterfinalists | Mission Mayhem Champs
2006: FL Delphi's Driving Tomorrow's Technology | Curie Quarterfinalists
Unread 14-01-2008, 23:01
2 for the robot and 2 for the ball. Possessing the ball takes away 2 unless you are hurdling. See Section 7.3.3 for scoring details.
Trackball inflation Laaba 80 Rules/Strategy 15 13-01-2008 12:59
Trackball PSI pumbaa2007 General Forum 2 12-01-2008 19:39
pic: Trackball vs. MiniFRC Trackball Jessica Boucher Extra Discussion 3 08-01-2008 03:08
Trackball scoring ZP8892 Rules/Strategy 6 06-01-2008 08:52
Rule Discussion: Possession Pavan Dave Rules/Strategy 28 12-03-2007 16:27
